Maricopa Emissions - Page 2 - Chevy and GMC Duramax Diesel Forum
Southwest Events AZ - CA - CO - NM - HI - NV - UT
post #11 of 16 (permalink) Old 11-09-2012, 05:00 PM Thread Starter
lockcop's Avatar
4 got to mention in my previous post that I would also have Rob delete the DPF in the EFI system that's in my trucks future.
So riddle me this batman. Are the DPF delete race pipes with bungs designed to "fool" the DMV folks? AND if you remove the stuff from inside the cat, reinstall it, install the DPF race delete pipe with bungs, hook up the wires, and get a flow through muffler but keep the stock size pipe wouldn't that be almost as good as getting a 4" or 5" system?
lockcop is offline
post #12 of 16 (permalink) Old 11-09-2012, 05:24 PM
I'm That Guy...
TDFDiesel's Avatar
You could try to get creative to "fool" someone, but the answer is NO... It will not pass the visual inspection, if you experience different results then you got lucky.
Different guys have tried different things like gutting the cats, but removing the DPF will be more challenging. I haven't seen a DPF delete that resembles a DPF.
Tony
Old Trucks: 1 - LB7, 3 - LLY, 1 - LMM
TDFDiesel is offline
post #13 of 16 (permalink) Old 11-11-2012, 07:04 AM Thread Starter
lockcop's Avatar
I would like to thank everyone for their comments.
lockcop is offline
post #14 of 16 (permalink) Old 05-23-2014, 05:33 AM Thread Starter
lockcop's Avatar
Well the old girl passed emissions with the hollowed out DPF and EFI set to Optimized Stock, #1 setting.
Kenneth a.k.a. lockcop 2007.5 LMM 2500HD ECSB 4 Wheel Drive
EFI AutoCal by Idaho Rob; DSP5 Switch In Power Port; Edge CTS2 with Pyro; Deviant Trans Lines from Alligator Performance; PPE Deep Trans + Oil Pan (TRANSYND), AFE Differential Cover + Trans Cooler from XDP; FASS T95 Lift Pump from Synthetic Motorsports; XD Tie Rods + Fumoto Valve from the DMAX STORE; ; POWERSTOP Z36 Drilled + Slotted;TIMBREN Suspension Enhancement System; Quad LED Fog Lights; OWENS diamond plate running boards; AERO 52 GAL Tank; Turbo Brake w/switch and light; Amsoil 20-50 Dominator Oil; Schaeffer Moly Grease, + Gear Lube; Temp Sensors In Oil Pan + Rear Diff; Dorman PS Cooler; Flowtie Emblem, Hillsboro 3500 Aluminum flatbed
Arizona Diesel Club #11
lockcop is offline
post #15 of 16 (permalink) Old 05-24-2016, 09:38 PM Thread Starter
lockcop's Avatar
Wink
Just passed again with a hollowed out kitty too this time. Blew a 15.7 out of a possible 40. The trick is to not hammer the throttle. Slowly down and slowly up to keep the smoke down. For the governor test I have the EFI set on #1 - optimized stock. For the 3 to the floor tests I have it set on #4 -race. Hope this helps.
lockcop is offline
post #16 of 16 (permalink) Old 03-12-2017, 07:41 PM
sandeater's Avatar
Going to dig up an old thread here
I have a 2014 and want to do exhaust. I will be moving from Tucson to Queen Creek/Gilbert area in a couple of weeks. What is the best exhaust system/setup to do so I can pass in Maricopa County?
2014 Sierra 2500 CCSB LML
sandeater is offline
