Any Vegas/Henderson people? - Page 7 - Chevy and GMC Duramax Diesel Forum
Southwest Events AZ - CA - CO - NM - HI - NV - UT
 5Likes
post #61 of 69 (permalink) Old 04-10-2017, 01:47 PM Thread Starter
I am deleted. Basically I have come to grips that once a year I will have to remove and reinstall stock pipes for inspection.
Zac808 likes this.
2015.5 All Terrain 7" BDS 38's
VegasJonny is offline
post #62 of 69 (permalink) Old 04-21-2017, 05:15 PM
Did you drop your transmission crossmember to remove/install exhaust system?
Sent from my SM-G920V using Tapatalk
2005 GMC SIERRA 2500HD 4X4 CC SB w/ Idaho Robs Tune, CTS2, 265/75 LTX M/S2s, B&W turnover ball w/ Andersen Ultimate Hitch, Rancho 9000XL's, MBRP 4" DP back w/ muffler, LBZ mouthpiece, AirLift 5000's, RDS 60G combo tank.
2014 Grand Design Reflection 337RLS (10,500lbs dry)
Zac808 is offline
post #63 of 69 (permalink) Old 04-25-2017, 09:36 PM Thread Starter
I did not. I should have since it would have been easier but its pretty simple to clamp back together using exhaust clamps after cutting.
post #64 of 69 (permalink) Old 04-25-2017, 09:37 PM
Gotcha. I am picking up an LML next week and trying to figure out my plan of attack.
Zac808 is offline
post #65 of 69 (permalink) Old 04-29-2017, 09:54 PM Thread Starter
Your welcome to use my 4 post lift. It makes things easier to work on for sure~!
post #66 of 69 (permalink) Old 05-05-2017, 12:16 PM
I will take you up on that. Is it at home or in a shop?
Which exhaust are you running? How do you like it?
Zac808 is offline
post #67 of 69 (permalink) Old 05-07-2017, 11:01 PM
DuramaxForum Guru
HD Dmax Machine's Avatar
A simple delete of just the DPF (DPF delete pipe) leave the DEF tank on just disconnect the hook ups & this will give the look of a stock appearance & its easier to put the truck back to stock form.
EFI Live, Edge Insight CTS, Flo~Pro 4" DP back exhaust w/ muffler & stock trumpet tip, Turbo resonator delete plug, Alum. bleeder screw, WIF sensor delete plug, Fumoto oil drain valve, Pacer LED cab lights, GM dually light bar under tailgate, Footwell lights, Cobra 29 WXNWST CB radio, Wilson 2000 CB antenna, Kenwood speakers, GM chrome oval running boards, Bilstein 5100s, Michelin Defender M/S on PY0 wheels, Rubber mud flaps, Curt class IV hitch
HD Dmax Machine is offline
post #68 of 69 (permalink) Old 05-10-2017, 10:14 PM Thread Starter
Its at my commercial space right next to the new Stadium
Its basically straightpiped. truck sounds like it should. Not sure if I have heard a truck that sounds like it to be honest with the tune I am running.
post #69 of 69 (permalink) Old 05-10-2017, 10:40 PM
DuramaxForum Guru
Around Vegas I don't see/hear many deleted Duramaxes. I talked to a guy here the other day that was tuned/deleted. He said Underground diesel shop (did his deletes & tuning awhile back) does deletes & does their own tuning. I knew of the shop/talked to them before but never done business with them. I didn't ask if they still do deletes & delete tuning.
