Ď05 Tahoe Heater Acting Funny - Chevy and GMC Duramax Diesel Forum
Suburban and SUV Discussion of Diesel Installed SUV's
 1Likes
  • 1 Post By Brianlibby791
post #1 of 10 (permalink) Old 04-05-2018, 08:49 PM Thread Starter
The heater in my wifeís Tahoe has started acting up the last few days and it has me baffled. When I start it up in the morning to let the engine warm, the heater will blow warm air. After getting out on the highway, the dang thing starts blowing cold air. I took it out for a spin this evening in 70 degree weather and it did the same thing. The heater core isnít plugged because both the feed and return lines going through the firewall are hot. The engine gets to operating temperature so I know the thermostat is working correctly. The coolant level is fine. Iím stumped at this point. Could it be the blend door actuator?
'07 Classic GMC LBZ CCSB 4x4 Dark Blue
Diamond Eye 4" exhaust| Transgo Jr| EFI Live by Kory| Alligator transmission cooler lines| Profab EGR Delete| Profab Downpipe| Profab Towflow Up Pipes| Ported and plugged
akhend is offline
post #2 of 10 (permalink) Old 04-05-2018, 09:51 PM
Brianlibby791's Avatar
Most likely, my Sierra does that from time to time as well. There is a reset procedure to fix it but itís a hit or miss on it actually working.
jdwarren likes this.
2004.5 GMC Sierra 2500HD SLT
  • 5Ē MBRP Straight pipe
  • Edge CS2 Tuner
Brianlibby791 is offline
post #3 of 10 (permalink) Old 04-06-2018, 05:04 AM Thread Starter
Thank you, sir. Iíll give it a try.
akhend is offline
post #4 of 10 (permalink) Old 04-25-2018, 10:08 PM
Hate to say it but head gaskets. Check the resivor tank in the morning before u start it. If there is still pressure itís definitely head gaskets.
Dieselcessna65 is offline
post #5 of 10 (permalink) Old 04-26-2018, 07:23 AM
jdwarren's Avatar
What makes you think this problem is due to a blown head gasket? How would that explain the HVAC temperature dropping? With a blown head gasket the engine will consume coolant, and he said his coolant level is fine.
I had a similar problem with a 2002 Grand Cherokee, which was known to have issues with the blend doors. That sounds like the most likely explanation to me. Although I'm not sure this is good news as compared to a blown head gasket -- the repair costs can be exorbitant due to the amount of crap that has to come out of the vehicle to access the doors. I heard of repair costs for this problem with my Jeep getting damn near $2,000.
2017 Silverado 3500 LTZ (Summit White) | CC SB SRW | Z71 | Duramax L5P | Undercover Ultra Flex bed cover | Draw-Tite front receiver | AIMS 3kw inverter-charger | Titan Travel Trekker 50-gallon auxiliary fuel tank
jdwarren is online now
post #6 of 10 (permalink) Old 04-26-2018, 08:16 AM Thread Starter
Thanks for all the replies guys. Iím pretty sure itís the blend door actuator because the rear will still blow warm when the front gets cool. Itís pretty intermittent too. It hasnít done it in about 2 weeks.
akhend is offline
post #7 of 10 (permalink) Old 04-26-2018, 08:47 AM
Administrator
jc1843's Avatar
Does sound like the Blend Door Actuator- that is the one over the trans hump, and the easiest to replace.
jc1843 is offline
post #8 of 10 (permalink) Old 04-26-2018, 01:49 PM Thread Starter
Thatís good to hear. Thank you, sir.
akhend is offline
post #9 of 10 (permalink) Old 04-26-2018, 02:07 PM
rock4xfab's Avatar
Low on coolant, air pocket, or head gasket can cause the same symptoms. What does the temp gauge read when it does this?
2006 SIERRA CC SB 2500HD 6.6 LBZ 179,000 and ticking
3" MBRP Down Pipe
4" Diamond Cat Back
5" SS tip
Edge CTS2
Intake resonator Plug
EFI LIVE DSP5 by ATP via BBP
AIRDOG2
Interior lighting to BLUE LED conversion
285/75/16
Leveling keys POWERSTOP Brakes.
rock4xfab is offline
post #10 of 10 (permalink) Old 04-26-2018, 07:39 PM Thread Starter
Itís done it at operating temp on down to just warm enough to heat the air. No rhyme or reason as far as that goes. Iím fairly certain itís the actuator at this point since the rear stays warm when the front cools.
akhend is offline
