LBZ using drop shackles with airbags - Chevy and GMC Duramax Diesel Forum
 1Likes
  • 1 Post By pigpen23
post #1 of 6 (permalink) Old 12-07-2019, 09:54 AM Thread Starter
Hello all,
I installed Airlift bags on my LBZ some time ago to address the squat issues while pulling my toyhauler. I am pleased with them. They did accomplish what I was hoping for.
However, unloaded with the bags at 5psi the rear of the truck really sits up high. I prefer the truck to sit level front to rear. Is it possible to do lowering shackles while utilizing airbags? I figured I could trim out the loaded / hitch weight with the bags. Seems like if you drop the rear of the leaf spring it would compress / crush the bags.
I have zero knowledge about lowering shackles but I do wonder how they hold up under the load of a trailer when towing (Im at roughly 18K GCVW towing). Of course, GM engineered the pickup for pulling. Do the shackles throw a wrench in things from a engineering standpoint?
https://www.amazon.com/McGaughys-Low.../dp/B00B0Z29J4
06 2500HD CCSB 4wd LBZ | Fleece Trans cooler lines |Red Head steering box|Edge Evolution CTS2 w/ EGT probe| Bilstein 5100s|Michelin Defender LTX M/S LRE| "OEM" Turbo Brake | Airlift # 88275 airbags
Enigma66 is offline
post #2 of 6 (permalink) Old 12-07-2019, 11:52 AM
pigpen23's Avatar
I've read numerous stories where people have used lowering shackles with airbags. I'm convinced it will work and am planning on ordering bags shortly here before snowmobile season begins.
Noble_dmax likes this.
Casey
2016 Denali 3500HD - Starting from scratch.
Drop shackles. 285/75R18 RTs on Factory Wheels.
2018 Silverado 2500HD - Sold
2015 Silverado 2500HD - Sold
2012 Silverado 2500HD - Sold
pigpen23 is offline
post #3 of 6 (permalink) Old 12-07-2019, 06:51 PM
carhauler's Avatar
If you want to do the 2" shackles and then bags you are fine on most trucks, My truck sits level with the trailer on and I would much prefer it sits the same way empty so I am going to do it myself. All of my dually's but the last 2 have been lowered and the only one that was at all a problem was my 09 with a 5/3 drop , I had to adjust the pinion angle and I replaced the Bump stops with Timbrens cause it would bottom out on a hard bump and the Timbrens absorb the hit where the factory bumps don't do much. 2" is not a big deal as to the tolerance's but it makes a lot of difference in getting the stink bug look empty out of it. There is more than enough tolerance in the Firestone or Air lift bags to tolerate 2"
2019 Chevy Dually Door handles/color matched 110 Gal transfer-flow bed tank / 20"AE wheels Mich. 265/60/20 defender tires /husky rear flaps /cargo box/weathertech mats.tinted glass, xpel on forward surfaces, blacked out pillars
carhauler is offline
post #4 of 6 (permalink) Old 12-07-2019, 09:21 PM Thread Starter
I used the Amazon link to McGaughys 2" as an example. Any tips on what drop I need? Is it as simple as measuring from ground to middle of fender lip on both axles get the variance and buy shackles the length of the variance?
Also, what is the best brand? I do tow, so I want something burly out of good ol' american steel. I tried Cognito first with no luck. Found these on eBay and they look real burly
https://www.ebay.com/itm/253713795614?ul_noapp=true
I have a message into seller on LBZ Availability.
Enigma66 is offline
post #5 of 6 (permalink) Old 12-08-2019, 04:39 AM
carhauler's Avatar
I believe those are the same ones that alot of guys used cause you can leave the bed alone , most all the other ones you have to bend or cut the pinch weld or they rub, they are a quality piece, and pretty level and with the bags you can keep it same ride height all the time with different loads.
post #6 of 6 (permalink) Old 12-08-2019, 06:02 AM
407driver's Avatar
You can use the drop shackles included with the Sulastic shackles to lower the rear end 1 1/2 inches and improve ur ride at the same time.
407driver is offline
