bilstein shocks ? - Chevy and GMC Duramax Diesel Forum
 1Likes
post #1 of 13 (permalink) Old 01-08-2020, 11:14 AM Thread Starter
bilstein shocks ?
I am old. and admittedly a little confused. But still mechanically active.
I have 2003 GMC 2500hd Sierra duramax 6.6L LB7 145K miles. I loaded up a lance 8'6" camper for last summer. But after a couple of months, i noticed a groaning sound from the front end. I have original ac shocks. every thing else seems tight. the shocks however look worn the rubber is cracked etc. The noise is very noticeable first thing in the morning, then settles down and only groans when i try a tight turn. Or put it in 4WD and turn tight.
I'd like to replace the shocks but i confused by all the options? I have air bags in the back. But i don't think the truck is lifted? I mean it's all stock and it's high? 'been looking at shocks and the bilsteins seem like the most recommended. But there are question about the lift? How do i know what the Torsion Key Lift is?
When i bought the truck, i remember i did something with the torsion bars to make the front end level. It had downward rake? I probable sound like an idiot. But i have forgot how i did it. I vaguely remember something about colors and height adjustments but just can't remember. I don't want to pay to have shock installed, at $80 an hour.
So How do i know what size shocks to buy? Measure the Old Ones? I live in a very rural part on Northern Ca so i normally buy online.
Thank ToOld
TooOld is offline
post #2 of 13 (permalink) Old 01-14-2020, 11:40 AM
HWI
HWI's Avatar
You can measure compressed and extended heights, but really as long as you don't have a lift kit installed the Bilstein 5100s you'll want are 24-186735 for the front and 24-186742 for the rear.
J83 likes this.
06 LBZ CCSB
With some stuff.
HWI is offline
post #3 of 13 (permalink) Old 01-14-2020, 11:44 AM Thread Starter
That's what i wanted to hear. Thank very much!!
-Shawn
TooOld is offline
post #4 of 13 (permalink) Old 01-14-2020, 11:47 AM
LHN...We ARE the Joneses
I run the 4600s....stock suspension height, air springs.
Should be touching the bump stops....if you have any left. Might wanna inspect those for condition, as they're in integral part of the suspension up front. You'll be in there for the shocks, easy replace at that time.
Shock replacement on these are barely a 1 level on a 1-10 scale (unless your tool box consists of a pair of pliers and a flathead screwdriver). I wouldn't even think of having a shop put 'em on.
Hook'em_Horns! is online now
post #5 of 13 (permalink) Old 01-14-2020, 12:15 PM
JimmyD's Avatar
I too have installed the 5100s on my dually and have very happy with them.
Hook is spot on. Changing out the shocks is something that you can do in your driveway with minimal tools.
09 GMC SLT Dually
Steel Gray Metallic
All options except sunroof
Mods so far:
DF DRW Club Member #161
JimmyD is online now
post #6 of 13 (permalink) Old 01-14-2020, 01:09 PM
Thank ToOld
https://www.rockauto.com/en/catalog/...+absorber,7556
Bilsteins are super expensive. The Gabriel "Max". are $40.
Gabriels are a good shock, and a good value.
LMLLover is online now
post #7 of 13 (permalink) Old 01-14-2020, 01:24 PM
Bilsteins are Lifer Warranty
post #8 of 13 (permalink) Old 01-14-2020, 04:00 PM
denarli6.6's Avatar
I run Bilstein 5100s all around. I am super happy with them. Price is very reasonable compared to others out there.
2016 LML Denali 2500
Mcgaughy's 2" drop shackle
Bilstein 5100
22x10 American Force Flux black w machined or Toyos on OEM wheels. Depends on the day of the week
Wehrli S300 kit w/ 66mm SXE
Profab Manifold & Up-pipes
Stock Trans For Now
Stock Sticks For Now
Air Dog 165 4G
denarli6.6 is offline
post #9 of 13 (permalink) Old 01-14-2020, 04:20 PM
5100s here as well. Still comfortable but does the job well when I am loaded. I replaced the bump stops as well. They were beyond shot. Both are a very easy install and I am not much of a wrench either.
I bought these
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
06 2500HD CCSB 4wd LBZ | Fleece Trans cooler lines |Edge Evolution CTS2 w/ EGT probe| Bilstein 5100s|Michelin Defender LTX M/S LRE| "OEM" Turbo Brake | Airlift # 88275 airbags
Enigma66 is offline
post #10 of 13 (permalink) Old 01-14-2020, 07:03 PM
I put the Bilstein 4600's on the front of my crew cab dually last month. I have air bags and haul heavy. Probably wouldn't hurt on the rear either but it is stiff enough it doesn't bounce up and down all the time.
Wish I had installed them when I first bought the truck. There was nothing wrong with the OEM shocks when I pulled them off, they're just way too lame for a heavy, hard working truck.
2012 3500 4X4 CCLB
blythkd1 is offline
