RC leveling kit issue - Chevy and GMC Duramax Diesel Forum
 1Likes
  • 1 Post By goobs
post #1 of 5 (permalink) Old 01-27-2020, 05:04 AM Thread Starter
Had 3.5" Rough Country kit installed by a shop. Idler arm went bad in less than 300 miles. Dealer did replace it under warranty since the truck only has 2200 miles on it, but they will not warranty anything suspension related from now on because of the lift, I understand that. So, maybe it was a just bad part from the factory, but I'm starting to hear a slight rattle again with only a couple hundred miles after new idler arm was installed, I'm thinking it may be going bad again. I don't have the front cranked all the way up so it rides pretty decent and it was aligned. It has a slight bump steer, but I expect that with a torsion lift. I expect that tie rods may wear a little prematurely with the lift, but never expected the idler arm to go bad, especially in this short time and never off road. Does anyone have any idea if something with the lift could be wiping the idler arm out this fast? Thanks
reddog69 is offline
post #2 of 5 (permalink) Old 01-27-2020, 09:32 AM
goobs's Avatar
post pics.
Garrett, that's 2-R's & 2-T's
2015.5 ccsb HC, deep ocean blue metallic, 2wd, cst 4" knuckles, camburg 1.25" uniball uppers, fox 2.5 dsc shocks, 17x9 fuel anza beadlock, 35x12.50 maxxis razr mt.
goobs is offline
post #3 of 5 (permalink) Old 01-27-2020, 10:06 AM Thread Starter
I'll get some pics later on. I don't understand why it would eat up idler arm. There are thousands of trucks on the road with this kit and the only thing I've heard is tied rods and ball joints going bad over time, but nothing wiping out almost immediately.
reddog69 is offline
post #4 of 5 (permalink) Old 01-27-2020, 01:41 PM
goobs's Avatar
there are so many possible factors at play here. too much crank, bad alignment, other worn parts, etc etc.
denarli6.6 likes this.
goobs is offline
post #5 of 5 (permalink) Old 01-27-2020, 03:58 PM Thread Starter
The truck only has 2300 miles on it, only around 200 on the idler arm, alignment was done after the lift was installed.
reddog69 is offline
