Properly Leveling a L5P - Page 5 - Chevy and GMC Duramax Diesel Forum
 11Likes
post #41 of 53 (permalink) Old 07-20-2018, 09:51 AM
Originally Posted by DmaxStoreJimmy View Post
From our site...
McGaughys Rear 2" Drop Shackles (2011+) | DMAX Store
We havent had any rub, but that will depend on tire size/wheel offset...
Question: When using the Kryptonite Keys. Do the bolts get turned back the factory distance to achieve the 1.5-2" lift or is it a trial and error?
2017||2500HD|LTZ|Graphite Metallic|L5P
2016||2500HD|LTZ|Autumn Brozne|LML || traded
gipperkid is offline
post #42 of 53 (permalink) Old 07-20-2018, 10:28 AM
Trial and error.
Sent from my SM-G955U using Tapatalk
2012- Denali HD 4x4 2500
Xpel clear bra, amp steps, Inyati Bedliner. Rancho RS5000 Steering Stabilizer-Rancho 9000XL Shocks
PPE PTO-front/rear/Allison covers with transynd and amsoil severe gear oil. Magna-flow DPF back exhaust.
48548 is offline
post #43 of 53 (permalink) Old 10-31-2018, 09:05 AM
Do I need to remove the overload spring in my 3500 to run drop shackles?
'18 GMC 3500 Summit White
'11 GMC 2500 Storm Gray CC Leveled
Cog UCAs | tie rod sleeves| Pitmann/Idler Supports | Fox 2.0 Performance Shocks| 305/55 20 Cooper LTZ's | Fuel Octanes| LEDs|----sold
mastrcruse is offline
post #44 of 53 (permalink) Old 10-31-2018, 09:29 AM Thread Starter
DmaxStoreJimmy's Avatar
No, drop shackles are fine with overloads.
-Jimmy (aka novaman64)
WWW.DMAXSTORE.COM
DURAMAX ONLY STORE 1-877-4MY-DMAX
KRYPTONITE STEERING
STAGE 5 ALLISON KITS FROM $1299.00
DmaxStoreJimmy is offline
post #45 of 53 (permalink) Old 10-31-2018, 09:46 AM
Thanks! And I was told that I'd have to modify any airbag system to work if I wanted to add one. Is this correct?
Also, reading the pinch seam has to be bent up or cut/trimmed. Is this correct?
post #46 of 53 (permalink) Old 11-25-2018, 02:18 PM
Mericanmssl's Avatar
I took 10 turns to get to level. I needed to be at level for plow install. Plan on kryptonite stage 3 with billsteins. I'm at 26.5 in. From hub to bottom of wheelwell front and back. Will that kit keep me at that level with minimal change in ride quality? Recommend any other steps...diff drop, etc. Thanks!
Mericanmssl is offline
post #47 of 53 (permalink) Old 11-25-2018, 02:21 PM
Actually plow is on but final adjustments and possible drop brackets this week. Had to get truck to level for that!
post #48 of 53 (permalink) Old 11-25-2018, 09:03 PM
UTEngineer's Avatar
I went with the Tuff Countrys 3.5 inch leveling kit that included replacement tubular-style upper control arms, torsion keys, shock spacers to reuse stock front shocks (for now), front differential drop spacers to return CV joints to proper angles, and the kit also came with limit straps to restrict any downward suspension travel beyond the recommended CV joint angles. My truck had a stock 3.25 inch rake and I chose to leave a 1/2 rake ... so lifted the front ~2.75 inches. Truck realigned very easily and I am very happy with how this leveling kit worked out. Tuff Country calls this kit a 3.5 lift kit ... it is truly a leveling kit ... and the kit I purchased from them is not even listed on their website because mine did not come with the 1 inch blocks and extended u-bolts for the rear ... which was great ... I did not want these extra parts because I did not want to lift the rear of my truck. Pretty sure I could fit 35s under the truck now ... maybe some day down the road when they have a speedometer reprogrammer available.
https://www.tuffcountry.com/lift-kit...2500hd-3500hd/
Mystaken818 likes this.
2019 Chevrolet Silverado 3500HD 6.6L Duramax (L5P) Crew Cab 4x4 SRW Standard Box High Country Loaded w/ Rear Entertainment Package, Fabtech 4 Suspension Lift w/ Heavy Duty Tie Rods, 35 Tires on 18x8.5 Vision Valor Wheels, Luverne Grille Guard w/ Parking Sensor Relocation Kit, Rhino Roll Bar (Sport Bar 2.0) w/ 8 Hella Off-Road Lights, Banks Derringer / iDash / Intake / DPF Back Exhaust, Fabtech Stealth Shocks w/ Front Limit Straps, Front & Rear Hellwig Sway Bars, Airlift Air Bags w/ Wireless Air, DuraFlap Mud Guards, S&B MAP Sensor Spacer, Kryptonite Heavy Duty Pitman and Idler Arm, Centramatics
UTEngineer is online now
post #49 of 53 (permalink) Old 11-27-2018, 05:23 PM
bigginch's Avatar
Could you post some pics of your set up? Im kinda leaning the same way.
2019 L5p crew cab with 2.5 inch leveling kit
bigginch is offline
post #50 of 53 (permalink) Old 12-24-2018, 11:55 AM
UTEngineer's Avatar
Sorry for the late response.
Below are the pictures.
I have since replaced the sock shocks ... well worth it ... should have done it at the same time.
Must warn you that I need to have my front driveline rebalanced.
No have a slight vibration when @accelerating in four-wheel drive ... could happen with any kit.
