Cognito 4-6 with Kings - Page 6 - Chevy and GMC Duramax Diesel Forum
 20Likes
post #51 of 82 (permalink) Old 11-04-2018, 08:04 PM Thread Starter
FROGMAN524's Avatar
Originally Posted by DmaxStoreJimmy View Post
Trucks looks great, I love the look of sidewalls. How do you like the 4.11's with 35's? Im going with 4.56's and 35's on my truck, just had one guy at the shop swap out his 4.56's for 4.30's.
So far Iíve only got about 500 miles on the new gears but theyíre pretty much perfect for 35s. Stock like revs, take off and acceleration although I think Iíve lost 1-2MPG anyway.
2020 GMC Denali HD CCSB L5P/10L1000 Allison 4x4
SOLD2016 Sierra 3500HD Denali CCSB SRW
UDP Tunes on V2/SOTF Switch/Danville 63.5 Billet-S480FMW Billet Twins by WCFab(Illusion Blue)/Exergy 100% Injectors/Exergy 12MM CP3/Banks Intercooler/HSP Billet Manifolds/PPE Up Pipes/PPE Oil Pan/PPE Deep Trans Pan/AirDog 165 II-4G/FloPro 5" SS Turbo Back/MBRP 6" SS Tip/CTS2 Insight/EDGE EGT Probe/EDGE 0-100 Boost Sensor/Cognito 4-6/Cognito Front Driveline/Cognito Swaybar/Cognito PISK/PPE Tie Rods/King 2.5 Resis/Air Lift 5000 Ultimate Bags/Air Lift Wireless One Compressor/Wilwood TX6R Brakes Front and Back/LT325/60R20 BFG KO2s/20x9 Method 309s/AMP Steps/Yukon 4.11s/Royalty Core RC1/Retrax Powertrax Pro MX/Titan STAFS 30 Gallon/JL C5s/JL 12TW3-D4/JL VX600/6i/JL XD300/1V2
Mike L Trans (Goerend R/Alto G3s/RatioTek)
SOLD2015.5 GMC Sierra 3500HD Denali CCSB
SOLD2007.5 GMC Sierra 2500HD SLT CCSB SDP Twins/Mike L Trans/ATP Tunes
If wishes were horses, beggars would ride.
FROGMAN524 is offline
post #52 of 82 (permalink) Old 11-04-2018, 08:43 PM
DmaxStoreJimmy's Avatar
Originally Posted by FROGMAN524 View Post
So far I’ve only got about 500 miles on the new gears but they’re pretty much perfect for 35s. Stock like revs, take off and acceleration although I think I’ve lost 1-2MPG anyway.
Cant complain about that when going from a HT tire to a offroad worthy 35". Prolly weight close to 1.5x stock wheel/tire setup.
-Jimmy (aka novaman64)
WWW.DMAXSTORE.COM
DURAMAX ONLY STORE 1-877-4MY-DMAX
KRYPTONITE STEERING
STAGE 5 ALLISON KITS FROM $1299.00
DmaxStoreJimmy is offline
post #53 of 82 (permalink) Old 11-05-2018, 08:42 AM Thread Starter
FROGMAN524's Avatar
Jimmy do you think my front driver side clunk could be a failed factory Cognito ball joint? Or something else? Clunks seem pretty common with these Cognito kits.
post #54 of 82 (permalink) Old 11-05-2018, 09:44 AM
Could be, jack up one side at a time of the front end, try and move the tire top to bottom... Can also get a big prybar and put it between the tire and the ground and lift and see if there is play or any noise. Body mounts can also cause a clunk, though I highly doubt mounts on a truck that new are shot.
WWW.DMAXSTORE.COM
KRYPTONITE STEERING
post #55 of 82 (permalink) Old 11-05-2018, 11:21 AM
BAMAWHISTLER's Avatar
lookin good Frogman, what made you choose not to do the BDS coilover up front?
2006 LBZ 2500 CCSB 2WD
EFI LIVE, DSP5, Edge CTS & EGT probe, PPE airbox mod, AFE hotside pipe, PPE manifolds/uppipes, MBRP DP, MBRP 4" side dumped, Sinister coldside pipe, pcv reroute, Beans sump, Kennedy lift pump, dual filters, coolant bypass filtration, Nuc Motorsports Oil Bypass kit, LML 20s & 265/60R20s, tint, LEDS, some chrome
ALABAMA LBZ Build Thread
BAMAWHISTLER is offline
post #56 of 82 (permalink) Old 11-05-2018, 08:54 PM Thread Starter
FROGMAN524's Avatar
It didnít really come to mind first of all and second of all Iíve always wanted a Cognito kit anyway. I might do a BDS down the road but I wanted to keep it between 4-6 inches to be able to get under a toy hauler with the bed not being too high.
post #57 of 82 (permalink) Old 11-11-2018, 08:39 PM
CDmax16's Avatar
Howís the truck coming along?
Wehrli intake bridge and AFE IC piping,Edge Insight cts2, AirDog II 165,SDP resonator delete, Mishimoto pcv catch can, MBRP down pipe,Recon led tail lights and third brake light, Morimoto mini D2S 5.0 projectors w/hidís, Morimoto 2stroke 2.0 ledís highs and fogs.
Kryptonite ucaís & tie rod sleeves, CCM diff drop,Fox 2.0 reservoirs, steering stabilizer, CalTracs,
Cognito PISK and heavy duty sway bar links, AirLift bags,
Nitro 4.30ís w/Nitro TracRite posi...
CDmax16 is offline
post #58 of 82 (permalink) Old 11-12-2018, 10:45 AM
reneg's Avatar
Howís the ride with the new set up? Same as stock or better? Also, is the front track width still the same as the rear, or is it wider?
reneg is online now
post #59 of 82 (permalink) Old 11-18-2018, 10:02 PM
AreliusChev3500's Avatar
Truck looks sick! I too love the Cognito systems but am wanting to run some coil-overs and toss the torsion bars. Check out Proformancediesel.com in the future. I will be looking them up shortly. They use Cognito lifts with King Coil-overs for the front suspension. Looks to be the ultimate set up in the front IMO. Throw that on with a Kelderman 6-8" out back and you have a little bit of heaven right there! Looks great though!!! Money well spent!!
2012 GMC 3500HD Denali CCLB DRW to SRW conversion!! Cognito 7-9" Lift de-cranked to 6", Cognito UCA's, CST Dual Shock kit Front, Fox Performance Reservoir shocks all four corners. American Force Justice 22X10 with Nitto Trail Grappler LT325/55R22. Sulastic Rear Shackles, MagHytec Rear Differential Cover. Curt Turnover Ball, Recon Smoked Cab LED Lights. BD Throttle Booster, AirDogII 165. What else? It's a fully loaded DenaliHD, no need to add!! I kid, there's always something to add. Full delete to come!!
AreliusChev3500 is offline
post #60 of 82 (permalink) Old 11-20-2018, 06:37 AM Thread Starter
FROGMAN524's Avatar
Wish I knew about that before. Oh well I like my kit.
