lifted truck drop hitchs - Page 2 - Chevy and GMC Duramax Diesel Forum
post #11 of 20 (permalink) Old 11-28-2011, 09:29 AM
la77chevy's Avatar
I couldn't find a B&W w/enough drop. I have the same Rapid Hitch as Blackcloud and love it. I pull several different trailers ranging from a 10' 4-wheeler trailer to a 26' car hauler and they're all different tongue heights and different ball sizes. The Rapid Hitch is easy to adjust and works great for all of my trailers. Not a single complaint here, highly recommend it
Brandon
-04.5 LLY, CCSB, 4x4,Silver Birch
-68mm Cheetah, Suncoast stage 4/triple disc converter
-ATS manifolds/Up-pipes, Profab EGR delete, 4''exhaust
-Diamone Eye DP, AFE stage 2, EFI Live (Rob's tunes)
-Airdog 165, Shimmed FPRV, Re-routed PCV, 3'' IC tubes
-Superlift 6'' w/traction bars, heavy duty bumpers
-35'' Nitto Trail Graps on Mickey Thompson Sidebitters
-LBZ MP, Sleeves, N-Fab step bars, HID's
la77chevy is offline
post #12 of 20 (permalink) Old 11-28-2011, 10:03 AM
Blackcloud556's Avatar
B&W has a 9" drop which should be enough for a 6" lift
Blackcloud556 is offline
post #13 of 20 (permalink) Old 11-28-2011, 10:12 AM
la77chevy's Avatar
I even pulled a 12x50 mobile home off mine It's still straight as an arrow and still adjusts just fine
Brandon
post #14 of 20 (permalink) Old 01-21-2018, 10:30 AM
P100DHG.'s Avatar
I have a 4 inch lift on my 2500 with 35 inch tires and Iím considering an 8 inch or a 10 inch drop hitch byway safe the 180 model any thoughts? Is 10 inches overkill I have a small trailer for a golf cart that doesnít sit very high off the ground 12Ē or so and I wanted to sit level I also donít want to hitch to sit too low where it bottoms out when I go up a gas station driveway
P100DHG. is offline
post #15 of 20 (permalink) Old 01-21-2018, 10:31 AM
P100DHG.'s Avatar
Canít figure out how to edit. I meant Weigh Safe.
P100DHG. is offline
post #16 of 20 (permalink) Old 01-21-2018, 10:42 AM
I have a geny that works great, heavy and solid. Not cheap, but will likely last forever.
https://genyhitch.com/product-catego.../drop-hitches/
corneredge is offline
post #17 of 20 (permalink) Old 01-21-2018, 10:49 AM
P100DHG.'s Avatar
. Whatís the proper drop for my size lift though?
P100DHG. is offline
post #18 of 20 (permalink) Old 01-21-2018, 12:32 PM
I measure my trailer and truck then chose the 10" can put the receiver in any of the levels
Sent from my SM-G930V using Tapatalk
post #19 of 20 (permalink) Old 01-21-2018, 04:21 PM
P100DHG.'s Avatar
what size lift and tires do you have?
P100DHG. is offline
post #20 of 20 (permalink) Old 01-30-2018, 10:14 PM
havasucat's Avatar
I use a bulletproof hitch they can make any size drop u need.
havasucat is offline
