Camper towing pics - Page 198 - Chevy and GMC Duramax Diesel Forum
 1451Likes
post #1971 of 2009 (permalink) Old 12-05-2019, 12:21 PM
NHfireDmax's Avatar
^^^^^ Strong work
jdwarren likes this.
2019 Quartz Red Denali HD Chrome deleted
NHfireDmax is offline
post #1972 of 2009 (permalink) Old 12-29-2019, 07:56 AM
jdwarren's Avatar
Leaving the Big Bend area.
Passengers.
Heading toward Wolf Creek Pass CO from the west; storm's comin'.
Chaining up for the pass. Roads were pretty squirrelly; several inches of accumulated snow on top of an ice sheet.
At the summit.
Finally on the east side. Blew the trailer right turn signal fuse at some point (probably due to salty water getting into the receptacle when I was connecting it), so I swapped it out before continuing on.
2017 Silverado 3500 LTZ (Summit White) | CC SB SRW | Z71 | Duramax L5P | Undercover Ultra Flex bed cover | Draw-Tite front receiver | AIMS 3kw inverter-charger | Titan Travel Trekker 50-gallon auxiliary fuel tank
jdwarren is online now
post #1973 of 2009 (permalink) Old 12-29-2019, 04:56 PM
Collins's Avatar
JDWarren:. 2 questions:
1. What tires do you have on the truck in pix?
2. My OM (19 2500) cautions against using chains on the rear wheels, and says not to use on front under any circumstances. Both seem silly on a vehicle with so much clearance. Looks like you aren't even using class S tight clearance chains. So, did you experience any interference problems with the chains on all 4's???
2019 Silverado 2500 4WD, Cajun Red
Michelin LTX M/S, bed liner, Alum bed box
Boost mirror turn signal jumper
Trans cooler grill
Collins is offline
post #1974 of 2009 (permalink) Old 12-29-2019, 05:14 PM
Duramaxdan59's Avatar
first trip in JUNE 19
onetigger725 and jdwarren like this.
2019 Silverado 2500 HD DMAX (L5P) Crew cab single wheel 4X4 LTZ Z71 Black on Black leather..
Diode Dynamic LED fogs ..
Heartland LED hi's and lo's
Boost Auto all 6 on hi Mod
Truxedo tonneau
Rubber bed mat
Eaz-Lift 16,000lb 5'er hitch
2018 30' Keystone Cougar 5'er
Duramaxdan59 is offline
post #1975 of 2009 (permalink) Old 12-29-2019, 06:49 PM
jdwarren's Avatar
I never even thought to look at the manual for this, actually. And no, I did not experience any issues (that I know of). Truck sailed up and down that mountain with no problems. Chains came off and went back in the bag afterward. I'm sure I could have gotten away with chains only on the rear, but given how nasty the roads were and the need for braking traction I figured I may as well put on all four.
On a related note, if you don't use chains, you may wind up like this...
...and sit there like an idiot trying to rock the truck out of a ditch when it's frame-deep in snow until a friendly Duramax driver named Will comes and pulls you out.
I offered to take him and his wife out to dinner and/or drinks but they had prior obligations (or didn't want to be seen in public with an NJ moron driving on snow-covered South Dakota dirt roads with Michelin LTX Defender all-season tires in the dead of winter, to answer your other question).
Fortunately, on our way back I was presented with an opportunity to partially redeem myself when I found another traveler who had a blown out tire without the tools requisite to change it. #PayItForward
post #1976 of 2009 (permalink) Old 12-29-2019, 07:42 PM
Collins's Avatar
Thanks JD. I have the same tires.
Solo on snow/ice, it probably makes more sense to chain the fronts due to the weight. But I'm not sure chains would have pulled you thru the place you were stuck.
On a 2 lane road outside Farmington, nm, we passed a truck/camper on the shoulder and just as we passed I caught a glimpse of an older gentleman struggling with a tire. I searched for a place to turn around for 10 miles. It still bothers me that I was not able to get back and assist.
Trans cooler grill
Collins is offline
post #1977 of 2009 (permalink) Old 12-29-2019, 08:02 PM
jdwarren's Avatar
So, basically we were being tourist morons trying to see Badlands National Park. Not sure we would have been able to see anything anyway due to the blowing snow. I didn't even realize we were driving on a high-crown dirt road because it appeared to be flat with some snow on the right side. Well, it was only flat because of the snow -- and it was about 12 inches deep. Which wouldn't have been an issue if I hadn't hit it at 35 MPH thus causing the truck to pull hard right, at which point it went off the road completely into several feet of snow. Screwed.
With the chains and going a little more cautiously I'm sure I'd have been fine. But after attempting to dig the thing out in 50 MPH gusts for an hour and getting covered in snow I was soaked and freezing and just wanted to get the hell out of there. And so we did.
Newsflash: you are an older gentleman. Well, older, at least. Unsure about the gentleman part.
Anyway, I understand the predicament. My policy is that if there is no life-threatening weather I only pull over to assist when the following two conditions are met:
1) The vehicle has an obvious mechanical problem that is currently being addressed; i.e., I see people trying to work on or fix things.
2) I have the ability to bring my own vehicle to a safe/controlled stop and fully clear the lane of traffic.
Today it was easy because I was only going about 50 MPH, I saw them well ahead of time, the shoulder was plenty large (and I had no trailer attached), and they were obviously trying to fix a problem. Plus, the weather was getting close to life-threatening without shelter so I was even more willing to help.
onetigger725 likes this.
post #1978 of 2009 (permalink) Old 12-29-2019, 08:34 PM
JD , is that a step on the front that fits a hitch?
2019 Chevrolet 4500HD CC 4X4 Flatbed
2018 Chevrolet 1500 CC 4X4 High Country 6.2 liter
2019 Chevrolet 3500HD CC 4X4 Flatbed--SOLD
2011 Peterbilt 337 hauler with 360HP 8.3 Cummins--SOLD
1957 GMC 1 ton flatbed with 22K original miles.
3 different Kubotas
2003 Chevrolet 2500HD CC: 2011 Chevrolet 3500HD CC 4X4 and 2013 3500HD ex. cab 4X4-- all sold.
sambor is offline
post #1979 of 2009 (permalink) Old 12-29-2019, 08:48 PM
jdwarren's Avatar
Sure is: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
post #1980 of 2009 (permalink) Old 12-29-2019, 08:54 PM
Collins's Avatar
Accurate, but........ouch. In my mind I'm still ....much .... less.... old.
Yes I have some criteria for stopping also, mostly around our security. If they had been younger or lots of people around I would not consider stopping. I'm a conspiracy theorist at heart.
The other day I passed a guy on the side of the interstate and he was changing a flat tire while open-carrying a .45 on his hip for all to see. Message received. (and what a great idea if you are in a state where it is legal).
Trans cooler grill
Collins is offline
