How do I adjust my WD Hitch? - Chevy and GMC Duramax Diesel Forum
post #1 of 14 (permalink) Old 02-21-2018, 06:22 AM Thread Starter
migz_74's Avatar
Hi everyone. I have a question regarding my weight distribution hitch. I recently purchased a new truck but the adjusted height is not the same as my old truck. I had a 1500 before and now I have a 2500. I know the height will be higher on the truck end. What do I do? Thanks
migz_74 is offline
post #2 of 14 (permalink) Old 02-21-2018, 10:44 AM
phat rat's Avatar
Is the head adjustable on the shank or welded? If welded you'll have to buy a new one or have the old one cut apart and rewelded. If you buy a new one buy one that's adjustable
07 GMC CC LB dually LBZ, DeeZee boards, 50 gal Transfer Flow inbed tank
2003 Crossroads 5th wheel
34' car trailer w/63" semi sleeper on the front
41 Ford hot rod 454/700R4
17 T roadster 270 Dodge Hemi 4spd
Dually club #202
phat rat is offline
post #3 of 14 (permalink) Old 02-21-2018, 10:53 AM Thread Starter
migz_74's Avatar
Phat rat. Its adjustable nothing is welded
migz_74 is offline
post #4 of 14 (permalink) Old 02-21-2018, 05:52 PM
Depending on what brand of WD hitch you have will determine how you adjust.
Mine has 2 bolts that hold the ball / bars to the receiver adapter.
Set both the truck and trailer on a level surface. Level the frame of the trailer without the truck hooked to it. Measure the height of the ball. Measure the height of the ball, and adjust to be about 1" higher than the trailer.
Tighten all bolts to specified torque by MFG. Hook up trailer and adjust chains so that there is about 1" of sag in the truck at the ball (hence setting the ball about 1" higher in the previous step).
2004.5 Silver Birch Metallic GMC K2500HD
18 Denali CCSB 2500 4WD Mineral Metallic with Cocoa/Dark Sand Interior
jlawles2 is offline
post #5 of 14 (permalink) Old 02-21-2018, 06:49 PM Thread Starter
migz_74's Avatar
Thanks, I've seen a few videos on you tube and I'm understanding the concept much more. I have a Husky Round bar hitch, which uses the chain links. The hitch was installed when I got the trailer but was not shown how to adjust it if I ever changed vehicles. I should have asked.
migz_74 is offline
post #6 of 14 (permalink) Old 02-25-2018, 01:19 PM
Chevy states that a WDH is optional even with a 18,000 lb. trailer load. With a 12,000 lb. trailer load I have never needed a WDH with my 2011 truck and its frame.
"In almost every case (where the United States has fought wars) our overwhelming commitment to freedom, democracy and human rights has required us to support those regimes that would deny freedom, democracy and human rights to their own people." - Gore Vidal
elkhornsun is offline
post #7 of 14 (permalink) Old 02-25-2018, 04:03 PM Thread Starter
migz_74's Avatar
elkhornsun I did hear something like that somewhere. My trailer weights around 6000 lbs. dry. So I should try it but I would have to adjust it accordingly.
migz_74 is offline
post #8 of 14 (permalink) Old 02-25-2018, 06:03 PM
I run the WDH not for the Weight distribution, but SWAY control in wind.
jlawles2 is offline
post #9 of 14 (permalink) Old 02-25-2018, 07:33 PM Thread Starter
migz_74's Avatar
yeah I would say it's good for safety reasons. The wind and those big rigs passing are no joke.
migz_74 is offline
post #10 of 14 (permalink) Old 02-27-2018, 03:10 PM
HD91733's Avatar
What brand & model wd is it?
HD91733 is offline
