New dually, question on tires and rims - Chevy and GMC Duramax Diesel Forum
 1Likes
post #1 of 12 (permalink) Old 03-20-2019, 05:53 PM Thread Starter
Someone talk to me about dually tires and aftermarket rims. I just bought a 2019 3500 dually. Love the truck, hate the wheels and mpg. I tow my 19k goose neck horse trailer basically all over the country. What's everyone running for aftermarket wheel tire set ups. I don't want to level the truck. What fits at stock height and how is everyone making sure there is enough clearance between the two rear tires? Looking for a set up that works with the truck as is, and doesn't kill ride or mpgs.
I have been looking at three different types of wheels Fuel FF31D, Fuel FF19, or XD Grenades all 20" set ups.
Anyone have any real world experience with similar set ups towing something reasonably heavy? Probably the wrong section, but I wanted ppl with towing experience.
Thanks
duramaxsp33d is offline
post #2 of 12 (permalink) Old 03-20-2019, 06:54 PM
M.A.M.'s Avatar
I’ve run a 20x8.25 for over 100k already. Try to find some direct bolt on 8 lug 20s, or they’ll stick out past your fenders quite a bit. The bolt ons still will a bit, but not nearly as much. I run 275/65/20s, and have plenty of clearance between the two rear tires, could go wider.
Those 100k were all towing, no issues. Stock suspension setup.
9/26/17 80k miles with no issues...
--2015 GMC 3500 SRW/CCLB--
Engine rebuilt @ 170,000 miles due to hole in cylinder #7
First start on 5/13/16
8/29/17 REBUILD 2.0 @ 295k miles
255k miles on 4/1/17, and goin' strong...
S&B Intake, 3" MBRP downpipe, Flo-Pro 5" downpipe back exhaust/no muffler, PPEI tuned no longer, MOONSHINE tuned by Tony @ RidgeRunner, Airdog lift pump...
Monitoring via CTS2
Engine
Fingers Oval Bowl pistons @ 17.5:1 .040 over
Carrillo rods
chromoly pushrods
SoCal Girdle
ATI Super-Damper
ARP main and head studs
Keyed crank and cam
SDP CP3 coversion w/ Sportsman pump
Suspension
305/55/20 MT Baja ATZ P3s on stock 20's...
Kryptonite tie rods/centerlink
BUILD THREAD
M.A.M. is offline
post #3 of 12 (permalink) Old 03-21-2019, 05:22 AM Thread Starter
Perfect thank you. Your truck looks great by the way. Tires and wheels look perfect.
M.A.M. likes this.
post #4 of 12 (permalink) Old 03-24-2019, 08:36 AM
Location: we live in a high mountain valley in the hi country of northern arizona
This "thread" has me confused. I am not aware of ANY modern medium duty truck wheel manufactured since the early 1930's that has a separate "rim". Unless there is something on the market in recent years ( other than some early World War Two "combat" wheels) in which the wheel and rim are separate ? ? ?
I remain unclear on what basis changing the wheels and/or tires GMC/Chevrolet trucks come out of the factory door with can significantly change mileage.
Can someone help me understand this ?
6686L is offline
post #5 of 12 (permalink) Old 03-25-2019, 08:19 AM Thread Starter
No tire/wheel combo is going to increase the mpg, but it already sucks big time (currently around 12-13 on the highway empty). So I didn't want to make it worse with larger tires.
post #6 of 12 (permalink) Old 03-27-2019, 09:36 AM
I think you should look at what your new truck is rated to tow with the original tire/wheel combos versus something with 20 in wheels. I know a SRW 3500 has different size tires VS a DRW 3500 due to weight ratings.
As for the mileage-- it's a big truck. I have a 2019 3500HD DRW 4X4 with a flatbed on it and I haul horse trailers as well. I get about the same as you unloaded and about 10 loaded.
2019 Chevrolet 4500HD CC 4X4 Flatbed
2018 Chevrolet 1500 CC 4X4 High Country 6.2 liter
2019 Chevrolet 3500HD CC 4X4 Flatbed--SOLD
2011 Peterbilt 337 hauler with 360HP 8.3 Cummins--SOLD
1957 GMC 1 ton flatbed with 22K original miles.
3 different Kubotas
2003 Chevrolet 2500HD CC: 2011 Chevrolet 3500HD CC 4X4 and 2013 3500HD ex. cab 4X4-- all sold.
sambor is offline
post #7 of 12 (permalink) Old 03-27-2019, 10:29 AM
JimmyD's Avatar
Actually when I went to 19.5s I gained about .4 MPG on the highway. But that is easily eaten up by the decreased mileage in town.
My normal MPG in town = 13-14.
Best I ever got on the highway = 18.5
All hand calc.
09 GMC SLT Dually
Steel Gray Metallic
All options except sunroof
Mods so far:
DF DRW Club Member #161
JimmyD is offline
post #8 of 12 (permalink) Old 03-27-2019, 10:44 AM
JimmyD's Avatar
Dup Post
09 GMC SLT Dually
Steel Gray Metallic
Mods so far:
JimmyD is offline
post #9 of 12 (permalink) Old 03-27-2019, 10:49 AM Thread Starter
I can deal with 10 mpg loaded, that is what my 2500 gets towing the trailer, but the empty mpg is crazy low. Maybe it will get better with more miles, only about 1200 so far?
As far as tire weight rating, the stock tires are only 3085lbs, not sure of the stock rims. The LT275/65R20 are rated 3750/3415. I forget what the rims are off hand, but were not an issue.
post #10 of 12 (permalink) Old 03-27-2019, 12:44 PM
hdrolling's Avatar
New wheels make the truck, I tow my 17'000lbs camper with no issues. As posted by MAM the 275/65 R20 fits perfect with nothing else needed. Plenty of gap in the rear wheels.
I raised mine up because I like the look but my wheel and tire package fit perfect at stock height.
2018 3500HD LTZ DRW
My build thread https://www.duramaxforum.com/forum/b...lly-build.html
GM DRW club member #224
hdrolling is offline
Similar Threads
Ford dually rims on my gmc dually dkatubi06 Wheels & Tires 1 09-23-2013 04:57 PM
wanted good tires or tires and 8x6.5 GM rims 265/75R16, 265/70R17 or 235/85R16 Load r jrsavoie Looking For/ Wanting To Buy 7 11-05-2012 06:26 PM
rims tires rims and more tires. lifteddmax35976 Wheels & Tires 16 08-28-2012 09:10 PM
Tires and/or tires and rims needed samdweezel05 Looking For/ Wanting To Buy 2 10-22-2010 04:32 PM
