Truck rides terrible towing? - Page 5 - Chevy and GMC Duramax Diesel Forum
 4Likes
post #41 of 50 (permalink) Old 05-29-2019, 03:28 AM Thread Starter
Got the weights.
I am probably a little heavier on the pin normally, right now I have my old trailer axles on the rack on the back of the trailer, 250 lbs. maybe.
F 4085
R 5700
pin 2800
GC 21025
04 GMC LB7 2500 SAC 45 injectors DSP5 EFI live from LDS, ported air inlet. 4" MBRP droning exhaust.
77cruiser is offline
post #42 of 50 (permalink) Old 05-29-2019, 04:05 AM
JimmyD's Avatar
With the removal of the axles from the back of the camper, your pin weight will increase.
Is your truck 2500 or 3500?
09 GMC SLT Dually
Steel Gray Metallic
All options except sunroof
Mods so far:
DF DRW Club Member #161
JimmyD is online now
post #43 of 50 (permalink) Old 05-29-2019, 04:17 AM Thread Starter
2500
post #44 of 50 (permalink) Old 06-01-2019, 08:23 PM Thread Starter
Ya wanted weights, I gave em & now nutin.
Looking for a 3500
post #45 of 50 (permalink) Old 06-01-2019, 08:31 PM
LHN...We ARE the Joneses
Originally Posted by 77cruiser View Post
.....pin 2800.....I am probably a little heavier on the pin normally,....
Looking for a 3500
You've found your cause AND solution.
Hook'em_Horns! is offline
post #46 of 50 (permalink) Old 06-01-2019, 08:59 PM Thread Starter
Just have to find the right one & long box or short.
post #47 of 50 (permalink) Old 06-11-2019, 01:52 PM Thread Starter
Well maybe not I hooked it up to a friends 2014 3500 today, not much difference. His was just a little better.
post #48 of 50 (permalink) Old 06-11-2019, 02:08 PM
3k lb PW is DRW territory.
However, I think your problem is more the out of proportion of PW.
You're over 21%.
Should be more like 15%....which is close to what your SRW should handle.
The DRW will handle it better than your SRW, but it's still gonna have a slam factory to it.
A 14k 5er should be gravy. Yours is nose heavy. Where are the tanks?
post #49 of 50 (permalink) Old 06-12-2019, 09:03 AM Thread Starter
Black & gray just ahead of the axles, 1 gray over the axles, fresh in the rear.
On the bright side he said mine pulled pretty good, he has a similar weight trailer, but he thinks this is heavier on the pin.
I think he put his bags up to 40lbs.
post #50 of 50 (permalink) Old 06-12-2019, 09:43 AM
D_R_C's Avatar
Maybe have your friend consider upping the airbags psi maybe to 60-80, maybe even load some supplies towards the rear.
I run mine usually between 70-80 with pin weight in the 2800 range with my Polaris ranger inside, total trailer weight loaded 13,500 lbs 32' toybox.
Dan
EFILive TCM Duramax Tuner
AirDog 4G100
DHD PCV re-route
D_R_C is offline
Similar Threads
Truck rides TERRIBLE need help 7" Skyjacker 17'WoodenWagon Suspension&Steering 1 09-06-2018 05:06 PM
Non-Z71 Truck rides much better than Z71 Truck. NachO_GMC 2017 and up (Non Powertrain) 8 03-28-2017 02:44 PM
terrible terrible milage, please help...anyone?? desertboy77 04.5-05 LLY Performance Parts Discussion 26 11-08-2010 08:03 PM
truck rides pretty bad with fabtech 8in kit silverado_on40s Suspension&Steering 2 07-08-2009 10:12 PM
