looking at new 4500/5500/6500 - Page 6 - Chevy and GMC Duramax Diesel Forum
 21Likes
post #51 of 64 (permalink) Old 11-17-2019, 10:27 AM
LHN...We ARE the Joneses
Even the MDs of old were de-tuned to lower HP levels.
Hook'em_Horns! is online now
post #52 of 64 (permalink) Old 11-17-2019, 10:47 AM
Was an unlimited mile warranty available on the Kodiak's when they were being built?
hankbambam is offline
post #53 of 64 (permalink) Old 11-17-2019, 12:03 PM Thread Starter
HI Hank,
The Pbrake is a drum type and it will not allow ANY movement in gear. Its the big drum at the diff yoke.
Torque and HP are derated for longevity under commercial operator conditions. I had a 2019 3500HD flatbed and didn't really notice much difference except the 4500 gets things moving alot quicker the the 3500 did-- probably due to trans gearing and the 4:30 gear set.
My mileage got better as it broke in and now averages 9.5-11.5 pulling 17-20K. I usually set my cruise @ 68-70. We don't have any big hills to pull down here but we found the truck will pull just about anything you can hook to it such as a trailer load of cattle @ 35K we had to deliver to buyer.
By now you probably found out that the truck has a governor set to 75MPH-- has to do with the tire speed rating I think.
2019 Chevrolet 4500HD CC 4X4 Flatbed
2018 Chevrolet 1500 CC 4X4 High Country 6.2 liter
2019 Chevrolet 3500HD CC 4X4 Flatbed--SOLD
2011 Peterbilt 337 hauler with 360HP 8.3 Cummins--SOLD
1957 GMC 1 ton flatbed with 22K original miles.
3 different Kubotas
2003 Chevrolet 2500HD CC: 2011 Chevrolet 3500HD CC 4X4 and 2013 3500HD ex. cab 4X4-- all sold.
sambor is offline
post #54 of 64 (permalink) Old 01-14-2020, 09:29 AM
Sambor, hankbambam
Thanks for all of the information in this thread. I was looking to set up exactly how you have it hankbambam, with the CM AL ER bed!!!
While I know that these trucks are meant to be loaded, I was wondering what type of fuel economy you are getting without a load or trailer?
Has anyone heard of a tuner planned for these trucks? I am more interested in a tuner to increase the maximum speed of 75 Mph.
Thanks in advance.
2012 Silverado 3500HD
sse01 is offline
post #55 of 64 (permalink) Old 01-14-2020, 09:44 AM Thread Starter
I get about 12 mpg on mine. Just rolled over to 10K.
Speed wise, the limiting factor is the rearend gears. 4:30 is what mine is and speed limiter is set to that. Tires are another item you need to look at for their speed rating.
If you go to GM Techlink the current issue has a chart explaining the speed ratings for the different gear rations available.
As for any tunes -- engine is basically a L5P. With different ecm programming and a smaller turbo to make boost quicker for more low end torque.
I don't have any problems getting my trailers moving fully loaded. My truck weighs 11082 with full fuel and tools. Yours should be a little bit less if you get the alum. bed and same wheelbase.
Holler if I can help you with anything.
3 different Kubotas
sambor is offline
post #56 of 64 (permalink) Old 01-14-2020, 09:58 AM
JimmyD's Avatar
Originally Posted by sambor View Post
...... Tires are another item you need to look at for their speed rating........
^^Extremely important on this type of equipment.^^
As as example, the 19.5" tires on my truck are only rated to 80 MPH.
Be careful.
sambor likes this.
09 GMC SLT Dually
Steel Gray Metallic
All options except sunroof
Mods so far:
DF DRW Club Member #161
JimmyD is offline
post #57 of 64 (permalink) Old 01-14-2020, 10:00 AM
Understood on the tire rating; would not set above the rating of the tire. Thanks for the responses!!!
sse01 is offline
post #58 of 64 (permalink) Old 01-14-2020, 10:17 AM Thread Starter
I think the goodyears on my truck show 72 or so on the sidewalls but their website shows that the rating was increased to 80. they are 19.5's as well, wheels are Alcoas and rated for 4500 each.
to change the speed limiting on the truck would require either the dealer reset it or a new programming. Not sure the dealer would do it depending on what gear you have in your truck and you want to exceed that rating.
Which truck did you get? Post a little info on it please.
3 different Kubotas
sambor is offline
post #59 of 64 (permalink) Old 01-14-2020, 10:41 AM
JimmyD's Avatar
Hard to go wrong with Alcoas.
09 GMC SLT Dually
Steel Gray Metallic
Mods so far:
JimmyD is offline
post #60 of 64 (permalink) Old 01-14-2020, 10:43 AM
I am still in the research phase. There was so little information a year ago that I elected to wait.
sse01 is offline
