14,000 lbs : Is Tow Haul Mode necessary? - Chevy and GMC Duramax Diesel Forum
 9Likes
post #1 of 39 (permalink) Old 06-21-2019, 11:33 AM Thread Starter
Hi,
I've got a 14,000 lb 5th wheel that I'm finally going to start using. My truck is a stock 04 3500 Silverado diesel dually 4x4. Is Tow Haul mode only helpful for the braking effect, or are there other reasons to use it?
Thank you.
Stummer
p.s. I've got an Insight CTS computer with an EGT probe installed.
04.5 LLY Allison 3500 LS eclb drw 4x4, 3.73 axle, auto trans, 32,000 miles only
edge insight CTS w/ fusion update; diamond eye 4" dp back quiet tone w/ muff, transfer case pump rub fix
07 toy hauler dry weight 14,000lbs GVWR 18,000lbs
stummer is offline
post #2 of 39 (permalink) Old 06-21-2019, 11:40 AM
LHN...We ARE the Joneses
Unlike a gasser, your T/H restores the Allison to function as it was built....a truck trans to tow with.
Disabling T/H calms and tames it down for proper Mall cruising, like an SUV.
Your fuel use will drop, along with your EGTs, using T/H anytime you hook onto a trailer.
Hook'em_Horns! is online now
post #3 of 39 (permalink) Old 06-21-2019, 12:13 PM
I think it raises shift points to maximize pulling power but to me also increases shift speed or firmness probably to help protect tranny while pulling all that weight. Just my thoughts as I have no real data to support this. But my truck definitely seems to shift more aggressive or firmer when this feature is turned on.
Sent from my iPhone using Tapatalk Pro
2018 GMC SLT 4x4 2500 crew cab
Sawtooth is offline
post #4 of 39 (permalink) Old 06-21-2019, 12:15 PM Thread Starter
Thank you Hook. That's very useful information. I've towed the big 5th wheel a few times without putting it in T/H mode, because I don't like the braking effect. And towed smaller things like my boat. No major hills.
I wonder if I've damaged the transmission?
stummer is offline
post #5 of 39 (permalink) Old 06-21-2019, 12:39 PM
No I would highly doubt it. Over a long period it might not be good for it though
Sawtooth is offline
post #6 of 39 (permalink) Old 06-21-2019, 07:27 PM Thread Starter
Just got home. Okay, thank you Sawtooth.
stummer is offline
post #7 of 39 (permalink) Old 06-24-2019, 07:59 AM
TH does raise the shift points to get the load moving and make use of torque. It also makes them more firm which requires higher pressures which keeps the slippage between shifts to a minimum which lessens the heat. Locks up the converter sooner as well. All of which accomplishes what Hook em stated above.
Why would you not want the braking effect when you are towing? I love mine-- don't have to use any brakes until later in the stop because the trans is already slowing rig down.
2019 Chevrolet 4500HD CC 4X4 Flatbed
2018 Chevrolet 1500 CC 4X4 High Country 6.2 liter
2019 Chevrolet 3500HD CC 4X4 Flatbed--SOLD
2011 Peterbilt 337 hauler with 360HP 8.3 Cummins--SOLD
1957 GMC 1 ton flatbed with 22K original miles.
3 different Kubotas
2003 Chevrolet 2500HD CC: 2011 Chevrolet 3500HD CC 4X4 and 2013 3500HD ex. cab 4X4-- all sold.
sambor is offline
post #8 of 39 (permalink) Old 06-24-2019, 09:48 AM
Sierraluva's Avatar
T/H also initiated torque converter lock earlier and for longer. You will want that to keep the temp down and will provide more applicable power.
EFILive by RidgeRunner. 🤘 Fuel system support hardware, CCM front Diff Drop, some LEDs to make night into day, got some big ol 20's and wide ass tires and a nice display to show me what's up under the hood-
2012GMC2500CCSB
Sierraluva is offline
post #9 of 39 (permalink) Old 06-24-2019, 12:56 PM Thread Starter
OK, thank you sambor and sierraluva, I'm convinced. I hauled my little boat 4000lbs w/ trailer this weekend, and I went ahead and put it on, the T/H mode, I mean. Glad to know this, b/c I'm about to start doing a lot of hauling. My assumptions about "brake only" w/ T/H mode could have led to a failed transmission! Live and learn, thank you to the forum, and those who responded to this thread.
sambor and Sierraluva like this.
stummer is offline
post #10 of 39 (permalink) Old 06-25-2019, 09:57 AM
407driver's Avatar
By using TH (to get the Turbo Braking) in any kind of mountainous terrain, in conjunction with Cruise Control and Manual Mode shifting to keep your RPMs between 1800 & 2400 you can use the truck to maintain a downhill speed of your choosing without using the brakes much if any.
It puts a smile on my face from ear to ear each and every time, just sitting and watching the truck work as it was designed to.
BIOTEC likes this.
407driver is offline
