Questions regarding factory brake controller? - Chevy and GMC Duramax Diesel Forum
 6Likes
post #1 of 21 (permalink) Old 07-12-2019, 05:50 PM Thread Starter
Howdy!
I have a new 2018 Chevrolet 3500 DRW with custom hauler bed that I purchased to tow my Cyclone toy hauler RV for fulltime RVing. This is the first truck I’ve had with a factory installed brake controller. Before my first tow with this truck my trailer was in the shop and had new drum brakes installed on all six wheels. I have adjusted the brake controller to the Max setting and don’t seem to get much braking from the trailer even when using it to manually brake the trailer. Never had these problems with my Prodigy brake controller in my other truck. Any recommendations before I claim underneath the 5er would be helpful an much appreciated.
“Happy Trails”
Chiefneon
Chiefneon is offline
post #2 of 21 (permalink) Old 07-12-2019, 06:27 PM
My first step would be to get a 7-way tester at Walmart or other source, about $10.. This will tell you all the connections that work, and those that don't. It will come in many occasions in the future, Im sure, if not for you, for someone else that's having problems. With a new truck, I wouldn't think there would be any problems with your truck. The older trucks, like my 2008 model were not setup at the factory to work with electric over hydraulic trailer brakes, but newer trucks should work just fine.
Ron Nielson
Ron Nielson is offline
post #3 of 21 (permalink) Old 07-14-2019, 02:07 PM
Curious if the drums where adjusted properly on the install.
Mtu Alum is offline
post #4 of 21 (permalink) Old 07-14-2019, 04:19 PM
LHN...We ARE the Joneses
This^.....well, not the drums, but were the brake shoes adjusted up properly after install?
Hook'em_Horns! is online now
post #5 of 21 (permalink) Old 07-14-2019, 04:36 PM
Collins's Avatar
Even if new brakes are adjusted, my experience is they will not perform great until the shoes wear a bit. The issue is New shoes have a larger radius than the drums when new, so it takes a while to get full contact of the shoe in the drum.
2019 Silverado 2500 4WD, Cajun Red
Michelin LTX M/S, bed liner, Alum bed box
Boost mirror turn signal jumper
Trans cooler grill
Collins is offline
post #6 of 21 (permalink) Old 07-26-2019, 11:23 PM
Not impressed with my controller as well, brakes are adjusted, trailer has over 10k miles on it. Previous tow truck was a ram, so only change was the truck.
Brent Weis is offline
post #7 of 21 (permalink) Old 07-27-2019, 04:24 AM
JimmyD's Avatar
My controller works just fine on my truck with the Raptor hooked up. No issues.
Brent Weis likes this.
09 GMC SLT Dually
Steel Gray Metallic
All options except sunroof
Mods so far:
DF DRW Club Member #161
JimmyD is offline
post #8 of 21 (permalink) Old 07-27-2019, 07:15 AM
Well, maybe next year I'll change out all the shoes. The brakes are currently working, you certainly know when they are not. Maybe I'm expecting too much.
Brent W
2019 Duramax dually
Fusion 325 toyhauler
post #9 of 21 (permalink) Old 07-28-2019, 06:37 AM
You said braking is poor even when manually actuating the brakes. Was this during a pull test? If not, you may wanna try a pull test to see how it goes. Should be able to lock the trailer brakes up by manually actuating the brake controller then putting the truck in D and giving it pedal to get 1000-1200 rpm.
JimmyD likes this.
Stock 2018 Silverado D/A 3500 LTZ
shadow747 is online now
post #10 of 21 (permalink) Old 07-28-2019, 07:20 AM
henry42's Avatar
Change over to hydraulic disc brakes if you want stopping power. Not a huge job to do but an unbelievable improvement. Trailer will then be able to stop truck!
“Insanity is doing the same thing over and over again, but expecting different results.” - Albert Einstein
2017 2500HD GMC Denali CCSB
henry42 is offline
