Truck noob hitch question - Chevy and GMC Duramax Diesel Forum
 1Likes
  • 1 Post By Sawtooth
post #1 of 4 (permalink) Old 09-05-2019, 04:39 PM Thread Starter
What do I have here, a 2.5" hitch with a 2" adapter in it? Truck noob, sorry. Trying to figure this out. Bought the truck used. With my hitch hardware, I can't get the pin all the way through to get the cotter pin to slide in.
Thanks
padurmax is offline
post #2 of 4 (permalink) Old 09-05-2019, 04:44 PM
gear jammer's Avatar
That is a 2.5" receiver with a 2" adapter in it. It looks like you need to buy a larger and longer pin for it. Most decent auto parts stores should have someone knowledgeable that can get you what you need.
05 LLY ZF6 Moonshine Tuned 230K South Bend Dual Disk
gear jammer is offline
post #3 of 4 (permalink) Old 09-05-2019, 05:03 PM Thread Starter
Thanks. Are those adapters usually loose, the pin holds it in place? They aren't welded or anything right? This one might be rusted in to place. I'm looking to tow about 10,000. As you can see on this label it's rated at 7,500lbs so I wonder if I need to go up a size and remove that adapter.
This is a 2011 3500HD.
So I guess my question is stick with the stuck in 2 inch adapter and get something like this:
https://www.amazon.com/CURT-45332-Lo.../dp/B004QEKGPU
or try to get that adapter out and go with something 2.5 inch?
https://www.amazon.com/CURT-45458-Co.../dp/B00IIOD3RM
Any thoughts?
padurmax is offline
post #4 of 4 (permalink) Old 09-05-2019, 07:02 PM
Yeah just go to 2.5” shank and be done with it.
Sent from my iPhone using Tapatalk Pro
sambor likes this.
2018 GMC SLT 4x4 2500 crew cab
Sawtooth is online now
