7" FTS lift for stock - Chevy and GMC Duramax Diesel Forum
Trade / Barter Have something to Trade? Skills to Barter? Post an ad here!
post #1 of 8 (permalink) Old 07-25-2018, 11:45 AM Thread Starter
I just picked up a 2006 GMC Sierra Duramax. It has a 7" FTS lift on it. I don't like that look for the truck so I'd like to trade for stock parts or a Zone Off-road 3" kit + cash. Below is the link to the exact kit.
http://ftskits.com/2001-2010-7-chevy...r-springs.html
RJames426 is offline
post #2 of 8 (permalink) Old 08-05-2018, 01:45 PM Thread Starter
I am looking for the Cognito UCA leveling kit, so I would trade straight up for that kit with the stock parts.
This FTS kit is nice because you don't have to cut the diff or cross member.
post #3 of 8 (permalink) Old 08-05-2018, 05:28 PM
DannyDmax's Avatar
Personally I would just use stock torsion keys and pull the bolts and take out the rear lift block. Should sit like a leveled truck and your front end angles would be perfecto
White 2004 CCSB 4x4 LB7 Duramax
Performance:
SAC45 Injectors from LDS, DmaxStore Intake horn, EFI Live from Rob, Kryptonite Tie Rod Sleeves, PPE Boost Increase Valve, Fass Lift Pump, 5" MBRP Straight Pipe, Cat Fuel Filter adapter, Edge CTS2 Insight
Cosmetic:
FTS 2.5" leveling kit, 22x12 American Force Burnouts, 305/45r22 Nitto Terra Grapplers, Retrax Bed Cover, Rain Guards, 5% side/rear window tint, 40% windshield tint, All LED lights, Debadged, Line-X Bedliner, Spiked lug nuts, OEM clear tail lights, clear third brake light
Check me out on instagram! - @lb7_danny
DannyDmax is offline
post #4 of 8 (permalink) Old 08-05-2018, 05:38 PM Thread Starter
The rear is lifted with new leafs, no blocks. This is my first truck, I'm coming from modifing cars, so I'm new to different components in truck suspension.
If I were to get stock leafs for the rear and stock keys, I should be able to lower it substantially? I believe the diff was dropped as part of the kit, I won't need to change this back to factory?
post #5 of 8 (permalink) Old 08-05-2018, 05:50 PM
Northwest Coal Roller's Avatar
you cant just return to stock... They have to the lower cross member out and replace it with a new drop cross member. There is a company I believe that had some sort of fix around this but i forget what it was. Best bet is to trade or buy a 4 inch lift that comes with a cross member, back the torsion bolts all the way out, and maybe a 1-2 inch block in the rear. Good luck!
2017 GMC Denali: 5% tint all around, 55% windshield, RC traction bars, 6" Fabtech, 20x12 Hostile Stykers, 35x13.5 Toyo A/T
2003 LB7 ECSB Too much air, too much fuel(Died 26May2017)
Daily Driver: 2014 Cruze TDI, cold air intake (best mod ever), 5% all the way around
PhotoBucket: http://s793.photobucket.com/user/mic...bock1/library/
Northwest Coal Roller is online now
post #6 of 8 (permalink) Old 08-05-2018, 07:18 PM Thread Starter
I would be replacing the cross member that comes with the kit with a stock one.
post #7 of 8 (permalink) Old 08-05-2018, 07:30 PM
DannyDmax's Avatar
Yes, that would lower it to somewhere around a 4 inch lift i assume. My friend had a 7-9 adjustable FTS kit on his LMM and he did the same as what I said and it looks like a leveled truck. Not sure why you doont have blocks but the stocks leafs should work.
Performance:
Cosmetic:
post #8 of 8 (permalink) Old 08-05-2018, 08:38 PM
So you will be welding the frame back in? There is nothing stock to replace with
