03 Duramax swap - Chevy and GMC Duramax Diesel Forum
 1Likes
  • 1 Post By Mike L.
post #1 of 5 (permalink) Old 10-07-2019, 12:10 PM Thread Starter
03 Duramax swap
Will a transmission from a 2002 Duramax fit in a 2003 duramax. Both Trannys are the LB7 but before I buy one I’d like to confirm its a straight swap.
Lyon.Crusade is offline
post #2 of 5 (permalink) Old 10-07-2019, 12:28 PM
rock4xfab's Avatar
I think they should if both are 5 spd, 06 was the change to 6 spd.
2006 SIERRA CC SB 2500HD 6.6 LBZ 179,000 and ticking
3" MBRP Down Pipe
4" Diamond Cat Back
5" SS tip
Edge CTS2
Intake resonator Plug
EFI LIVE DSP5 by ATP via BBP
AIRDOG2
Interior lighting to BLUE LED conversion
285/75/16
Leveling keys POWERSTOP Brakes.
rock4xfab is offline
post #3 of 5 (permalink) Old 10-07-2019, 12:36 PM Thread Starter
Yeah both are 5 speeds. I read somewhere that there is differences but I also had people say there isn’t.
post #4 of 5 (permalink) Old 10-07-2019, 02:13 PM
DIRTEEMAX's Avatar
The difference might be the something to do with programming . Id make sure they both plug in the same because I think 2003 was a different animal electronics wise . Also make sure the NSBU is the same .
2002 2500HD 4x4 ccsb
EFI live Idaho Rob
LBZ CP3 and regulator
4'' lift
Ultra Predators
Toyo RT's
WHEN GUNS ARE OUTLAWED I'LL BE THE OUTLAW !!
DIRTEEMAX is offline
post #5 of 5 (permalink) Old 10-07-2019, 08:40 PM
Same trans except cooler fittings might be different. There was a fitting change mid year. There are adapters to fit either way. Programming difference is total bullshit. Guess people want to post hearsay to sound smart.
If you can't prove your answer, stay the hell out guys.
BoiseRob likes this.
Mike L. is offline
