Wierd Slip/jerk in reverse on new tranny - Chevy and GMC Duramax Diesel Forum
post #1 of 10 (permalink) Old 08-11-2015, 09:30 AM Thread Starter
rhurley's Avatar
Getting a very sudden jerk when I put the truck in reverse, foot on the brake, the minute I take my foot off and roll. The truck jerks hard. First few times it happened I thought I hit another car.
I can re create it everytime too. I can go in reverse. it jerks. stop. drive. reverse jerk.
Any thoughts? brand new tranny from Mike L. has about 5000 miles
2015.5 Chevy 3500HD LTZ Z71 CCSB SRW. Summit White
BDS 4.5 w/FOX-Fuel Maverick 20x10s
Toyo R/T 35x12.50
PPEI Tuned, 5" exhaust, Airdog 4G, PPEI intake, EDGE CTS
SOLD 03 2500 built trans/efi/leveled
1972 Nova Built 350 w/ 700r4
1966 Mustang 5.0 efi T-5 scca track car
1984 K10 400hp sbc on 40s
1999 gmc 2500 - daily
2010 Caddi CTS - ol ladies ride
rhurley is offline
post #2 of 10 (permalink) Old 08-11-2015, 09:41 AM
SilverGorillaLML's Avatar
Contact mike, he will probably chime in at some point though.
Race/Pulling truck:2012 CumminGs/Built 6.8L/Big air/Big fuel/48RE Swap/PCS 2000/B&M Gated shifter
Kid hauler: 08 Lincoln navigator
Work/dd: 02 4.3 RCLB Silverado
SilverGorillaLML is offline
post #3 of 10 (permalink) Old 08-11-2015, 09:45 AM Thread Starter
rhurley's Avatar
Already called him,
Says its normal, but its now at the point where its rough and happens everytime. I get the feeling I am bothering him, so I figured I would see on here before I call him again
Toyo R/T 35x12.50
rhurley is offline
post #4 of 10 (permalink) Old 08-11-2015, 09:48 AM
FROGMAN524's Avatar
Same thing happened with my Mike L. I believe it was a matter of the increased line pressure or something to do with the valve body but I don't remember.
2016 Sierra 3500HD Denali CCSB SRW
UDP Tunes on V2/SOTF Switch/Danville 63.5 Billet-S480FMW Billet Twins by WCFab(Illusion Blue)/Exergy 100% Injectors/Exergy 12MM CP3/Banks Intercooler/HSP Billet Manifolds/PPE Up Pipes/PPE Oil Pan/PPE Deep Trans Pan/AirDog 165 II-4G/FloPro 5" SS Turbo Back/MBRP 6" SS Tip/CTS2 Insight/EDGE EGT Probe/EDGE 0-100 Boost Sensor/Cognito 4-6/Cognito Front Driveline/Cognito Swaybar/Cognito PISK/PPE Tie Rods/King 2.5 Resis/Air Lift 5000 Ultimate Bags/Air Lift Wireless One Compressor/Wilwood TX6R Brakes Front and Back/LT325/60R20 BFG KO2s/20x9 Method 309s/AMP Steps/Yukon 4.11s/Royalty Core RC1/Retrax Powertrax Pro MX/Titan STAFS 30 Gallon/JL C5s/JL 12TW3-D4/JL VX600/6i/JL XD300/1V2
Mike L Trans (Goerend R/Alto G3s/RatioTek)
SOLD2015.5 GMC Sierra 3500HD Denali CCSB
SOLD2007.5 GMC Sierra 2500HD SLT CCSB SDP Twins/Mike L Trans/ATP Tunes
If wishes were horses, beggars would ride.
FROGMAN524 is offline
post #5 of 10 (permalink) Old 08-11-2015, 09:53 AM Thread Starter
rhurley's Avatar
what was the fix?
Toyo R/T 35x12.50
rhurley is offline
post #6 of 10 (permalink) Old 08-11-2015, 01:06 PM
FROGMAN524's Avatar
There was no fix. I had to live with it. I usually hear about the hard shift from park to reverse or park to drive ONLY with built transmissions.
post #7 of 10 (permalink) Old 08-11-2015, 01:56 PM
Mine does what you describe but not bad at all, It sure don't bother me much.
Black 2006 LBZ, 2500HD 4x4 CCSB
Dyno Tuned by Mark Broviak 653hp/1213tq
DanvilleGT3794 Stage2 with Batmo-Wheel
Exergy Sportsman CP3
Suncoast Raybesto Gpz Clutches & 1056 Converter thanks to Seth Sullivan
Mike L Trans Cooler
All-Season Hot & Cold Side Intercooler Tubes & 3" Y-Bridge
Airdog II 165
Kryptonite Tie-Rods, Motor Mounts & Transfer Case Brace
Magnaflow 3" Downpipe & Factory Exhaust Gutted with 5" Chrome Tip
Nitto Ridge Grappler 295/55/20
OleBlackyLBZ is offline
post #8 of 10 (permalink) Old 08-11-2015, 01:59 PM Thread Starter
rhurley's Avatar
Like put it in reverse and coast backwards and feels like you hit a curb?
Toyo R/T 35x12.50
rhurley is offline
post #9 of 10 (permalink) Old 08-05-2019, 12:20 PM
Rvkecl05's Avatar
I believe it does have something to do with the higher line pressure mine is a 2013 with a stock transmission and a new TCM from Kennedy diesel ever since I changed out the TCM that has updated programming by Kennedy it has done the same exact thing. I have noticed however with mine it's not all the time and as long as I hold the brake put it in reverse and wait a few seconds before I let off the brake it usually doesn't happen if I put it in reverse and then let off the brake right away that's when I feel the sudden jerk. It almost feels like it's slipping. The truck starts moving stops and then starts moving again.
Rvkecl05 is offline
post #10 of 10 (permalink) Old 08-05-2019, 01:15 PM
Rvkecl05's Avatar
Rvkecl05 is offline
