Trany Overheating Going Downhill - Chevy and GMC Duramax Diesel Forum
 4Likes
post #1 of 13 (permalink) Old 07-15-2018, 03:24 PM Thread Starter
Send a message via AIM to cinno Send a message via Skype™ to cinno
Just completed a 5500 mile trip out west in the mountains with my 9K lb 5th wheeler and had two events where the trany overheated (red zone) only when going downhill in 1st gear on a 10 percent grade. Had to pull over both times to let it cool. 2nd gear 8% grades no problems. Up hill no problems either as long as I didn't push it to hard. The trany was the only problem, the engine was at normal temp. So why did the trany overheat going downhill? The engine revs was near the red line ~3900. Was in in tow/haul mode.
Cinno
2006 HD2500 LBZ, with Dual Fuel Filter and Lift Pump, 40 gal in bed fuel tank, one fuel heater and three fuel filter heaters.
cinno is offline
post #2 of 13 (permalink) Old 07-15-2018, 06:57 PM
07Dmaxx93's Avatar
Might be time for fresh fluid or a trans cooler
Sierraluva likes this.
2007.5 CCSB LMM
EFI live ECM Tuning by PPEI
S369SXE by WCFab
Fass 150GPH
XDP Sump
Instagram: 07Dmaxx
07Dmaxx93 is offline
post #3 of 13 (permalink) Old 07-15-2018, 08:43 PM Thread Starter
Only 10,000 on new fluid and new trany cooler.
Cinno
cinno is offline
post #4 of 13 (permalink) Old 07-16-2018, 08:14 AM
407driver's Avatar
two thoughts come to mind.
1. By being in 1st gear and 3800 RPM the heat generated by the transmission spinning so fast internally coupled with the slow speed which decreases the airflow through the cooling stack was limiting the ability of the stack to cool your TF.
2. When was the last time you cleaned that cooling stack? If it is plugged with bugs, etc, that too can severely limit the ability of the cooling stack to cool the fluids. This seems less likely to me becasue the rest of the fluids were normal you said
FASS 95 Lift Pump (with Baldwin filters), Edge Insight CTS Monitor on a Windshield Mount, Nicktane Fuel Filter Adapter w/ CAT 306-9199 UHE tertiary fuel filter, Bilstein 5100 Stock Height, MBRP Downpipe back 4" exhaust with muffler and FTE 30" resonator/muffler, Sinister EGR Delete, Tuned but wont say who did it, Bushwacker Bed Rail Caps, AMP Research Bedstep, Fumoto oil drain valve, Dorman PS Oil cooler, Pioneer AVIC 7200NEX GPS/Stereo, Air Lift LoadLifter 5000 Air Bags.
407driver is offline
post #5 of 13 (permalink) Old 07-16-2018, 08:38 AM Thread Starter
I never overheated the engine so I believe cooling stack is OK. The vehicle speed was about 25 mph and so that reduced the air flow some what.
Maybe the turbo brake I have heard about could help as maybe that would have kept me in second gear with torque converter locked.
The switch backs limited my speed to 25 max so maybe a electric fan would have helped.
Cinno
cinno is offline
post #6 of 13 (permalink) Old 07-16-2018, 08:48 AM
407driver's Avatar
Cinno
The bad news is that your LBZ does not have a Turbo Brake from the factory. The good news is that it is in the logic of your ECM. Here is a link to a thread I started when I put it in my last truck. I was not the one who discovered this however so in the first paragraph I gave credit and a link to the original thread.
https://www.duramaxforum.com/forum/0...lmm-works.html
I think you need to read both his thread completely and my thread completely if you wish to do this. I HIGHLY recommend it. For less than $20 you will not believe what a HUGE difference the TB makes going down hill. I was on some 7% grades day before yesterday. NEVER touched the brakes, the TB did it all and held whatever speed I had cruise set at.
Good Luck. If you have questions, I will be happy to assist, as I did with a guy in the thread I started.
post #7 of 13 (permalink) Old 07-16-2018, 11:13 AM
jdwarren's Avatar
Cinno
I'm speculating here, but I believe the torque converter will be unlocked in 1st gear, even in T/H mode. With the TC unlocked, there will be viscous heating due to the difference in speed between the input and output shafts of the TC. At 3900 RPM there will be a significant amount of heat addition to the transmission fluid and the low vehicle speed means limited heat dissipation. Maybe put it into manual mode and keep it out of 1st gear and use the service brake a bit more.
07Dmaxx93 likes this.
2017 Silverado 3500 LTZ (Summit White) | CC SB SRW | Z71 | Duramax L5P | Undercover Ultra Flex bed cover | Draw-Tite front receiver | AIMS 3kw inverter-charger | Titan Travel Trekker 50-gallon auxiliary fuel tank
jdwarren is online now
post #8 of 13 (permalink) Old 07-16-2018, 12:29 PM
D_R_C's Avatar
Using first gear (bad choice) you eliminated the option of the trans design to help control some braking.
Wrong wording but most should be able to finger what I said out.
Yes, the towhaul works in 2nd up, not first gear.
Was you using towhaul (recommended) or just in drive ?
It might just be me, but I would never red line or go above 3000 - 3200.
Just asking for future trouble IMO.
Dan
EFILive TCM Duramax Tuner
DHD PCV Re-Route
AirDog 4G100
D_R_C is online now
post #9 of 13 (permalink) Old 07-16-2018, 01:53 PM
830king's Avatar
This is exactly what I was thinking, but you beat me to it.
Sent from my SM-G930V using Tapatalk
jdwarren likes this.
My name is Dan, I drive a 2005 2500hd ccsb lly 4x4, victory red, Efi live Robs trans safe tunes, Edge cts w/pyro, Silverline 5" exhaust, Magnaflow downpipe, LML ds manifold, Arp head studs, S&b turbo inlet, S&b cai dry filter, Ppe shim kit, drilled fuel rails, B&w turnover gooseneck, Ma welded waterpump, Profab egr delete, Fass titanium 150, Beans fuel sump, Ma pump rub plate, 285/75-16 duratrac on stock rims, Kryptonite tie rod & centerlink, Kryptonite sway bar end links, kryptonite lower ball joints Rare parts extreme duty pitman and idler arms, Dhd steering brace, Alligator 5/8" trans lines.
830king is offline
post #10 of 13 (permalink) Old 07-16-2018, 06:21 PM Thread Starter
Yes tow/haul. I think using first gear is the only real choice as riding my brakes down a 8 mile 10% grade may have faded the brakes. The speed limit on the switch backs was 25 MPH, and 1st was the only gear that would reduce the speed without brakes given the weight of my rig. Using braking and 2nd gear engine braking may have done it but that would have been experimenting which would have been to dangerous, if it resulted in the loss of braking do to fade. Stopping and letting it cool was my only choice.
This topic was started so I could confirm what I always suspected and that is the torque converter does not lock up in 1st gear. Given that fact I believe my choices for future extreme mountain towing are; increase trany cooling with aux cooler with electric fan (in series with stock cooler) , and turbo braking. I'll look into these mods before next years towing adventures.
cinno
cinno is offline
