ZF6 clutch recommendations - Chevy and GMC Duramax Diesel Forum
post #1 of 2 (permalink) Old 04-10-2019, 09:22 AM Thread Starter
2002 LB7 with ZF6. I am currently stock but have plans to go up to about 425hp...no more than that.
Currently the clutch is making a tapping sound in the bell housing, I think this is the dual mass flywheel springs having broken. Would you guys recommend a single mass flywheel? I have heard good things about south bend clutch, what do you guys think?
cric8192 is offline
post #2 of 2 (permalink) Old 04-13-2019, 08:26 AM
South bend are one of the best IMO.
2011 GMC 3500HD DUALLY Welding Bed, 4WD CREW CAB, 4" downpipe back exhaust, def delete, egr delete, with new LB7 up pipe, pcv reroute, Fass 150, EFI live with DSP 5, HSP CAI. Air Lift Air bags.
mray is offline
Similar Threads
Recommendations for efi on a 05lly with a zf6 lb7dirtymaxx EFI Live 2 12-26-2013 12:08 AM
03 lb7 zf6 clutch pedal went boom josiecr 01-04.5 LB7 Performance Parts Discussion 6 07-07-2011 10:13 PM
Zf6 clutch slave fluid josiecr 01-04.5 LB7 Duramax Powertrain 1 08-12-2010 05:28 PM
