Danville Stage 2 GT3794 Batmowheel Turbo - Page 97 - Chevy and GMC Duramax Diesel Forum
Turbo's Stock and Aftermarket. Place for all your turbo questions
 66Likes
post #961 of 966 (permalink) Old 08-13-2019, 08:58 AM
Shanester's Avatar
Originally Posted by OleBlackyLBZ View Post
Shanester are you running a stock motor?
Yes, sir.
2006 LBZ S.B.C.C. LT 4X4
Cognito 4" NTBD
Exergy 45% & Exergy Sportsman CP3
EFI LIVE with DSP5 Thanks Mark
Danville Stg. 2 GT3794 Thanks Mark
Built tranny with Limitless 1078 Thanks Mike and Evan
Shanester is offline
post #962 of 966 (permalink) Old 08-14-2019, 10:00 AM
Originally Posted by Shanester View Post
Yes, sir.
Are you on stock Injectors and Cp3 as well? And do you have any idea what kind of power you putting down or are you just running emailed tunes..
Black 2006 LBZ, 2500HD 4x4 CCSB
Dyno Tuned by Mark Broviak 653hp/1213tq
DanvilleGT3794 Stage2 with Batmo-Wheel
Suncoast Raybesto Gpz Clutches & 1056 Converter thanks to Seth Sullivan
Mike L Trans Cooler
All-Season Hot & Cold Side Intercooler Tubes & 3" Y-Bridge
Airdog II 165
Kryptonite Tie-Rods, Motor Mounts & Transfer Case Brace
Magnaflow 3" Downpipe & Factory Exhaust Gutted with 5" Chrome Tip
Nitto Ridge Grappler 295/55/20
OleBlackyLBZ is offline
post #963 of 966 (permalink) Old 08-14-2019, 10:11 AM
Shanester's Avatar
Injectors are Exergy 45% and Exergy Sportsman CP3. Mark's tunes via email. I have no idea about actual hp though.
Cognito 4" NTBD
post #964 of 966 (permalink) Old 08-14-2019, 02:19 PM
Just to share...I was on my tune 3 (470hp) the other night and raced a buddie of mine who also has a crew cab lbz but he was on a stock turbo and a 450hp tune, and we done a rolling 1st gear non-boosted pull because I wanted to see if he jumped out ahead of me with the smaller stock turbo. It didn't happen, I pulled on him as soon as we nailed it. So all the claims of stock spool-up are not exaggerated.
Mike L Trans Cooler
Airdog II 165
post #965 of 966 (permalink) Old 11-22-2019, 02:27 PM
Boost Lee's Avatar
Does anyone have any experience with the standard 3794 directly from garrett? I cant find much info on them at all, as most everything i find is related to the Danville variations. I have an 05 lly, lbz pistons, lb7 pistons, keyed crank and cam, suncoast trans, lift pump, modified lbz cp3, head studs, werhli y bridge , flo pro manifolds and up pipes, 3" downpipe, full exhaust , fuel rail plug etc. I purchased a standard cast 3794 directly from garrett. My truck is a daily driver and i occasionally pull a trailer. I am hoping to get close to 600-650hp after i upgrage my injectors. I am hoping someone has some experience with this charger to let me know if it is capable or if i should send it in to have it modified by danville to make it a stage 2.
05 LLY RCLB
Boost Lee is offline
post #966 of 966 (permalink) Old 11-22-2019, 03:35 PM
#SecretSquirrel
TowU4Free's Avatar
Send a message via Yahoo to TowU4Free
Boost Lee,
I personally dont have experiance with the charger as a base and it has been quite some time since i have been in the diesel performance game. BUT, i can tell you with 100% confidence if you do not sent it to Danville you will wish you did later on. If my memory serves me correct Mark installs custom vanes, wheel and a few more modifications. His turbo room is absolutely incredible! I loved the turbo when i ran it, i almost with with a 4094 before i talked to Mark.
Short answer is, its WELL worth your money to send it to Mark. No question about it. Hope this helps!
07.5 LMM "CL1MAXN"
Some Detrimental Go-Fast Goodies...
7.30 @ 95MPH Thanks To..
Mark, Evan, And Dan
TowU4Free is offline
