Taking Care of Your Tires Properly! - Page 6 - Chevy and GMC Duramax Diesel Forum
post #51 of 58 (permalink) Old 01-13-2013, 11:23 PM
jtyson8602's Avatar
If you are still running stockers, then you can run what your door says if you like. I don't know if the plow package is why they say to run higher pressure, but really it is a matter of preference, I run 65 psi so my tires wear even when empty. When towing I bump it up. I would imagine you would want more pressure when you have your blade on too.
2006 GMC CCSB
jtyson8602 is offline
post #52 of 58 (permalink) Old 04-27-2013, 11:46 AM
DuramaxForum Guru
HD Dmax Machine's Avatar
I take the door jam recommendation (Front 60psi, Rear 80psi) & add/remove air pressure depending on how it rides & wears. Like 80 in the rear when empty is too much. 60 in the front gives a nice ride, but I was getting too much wear on the outside of the tires. After many times of adjusting my tire pressure, I finally stuck with 74 in the front & 58 in the rear, (when empty.) I put 80 in the rear when towing/hauling.
EFI Live, Edge Insight CTS, Flo~Pro 4" DP back exhaust w/ muffler & stock trumpet tip, Turbo resonator delete plug, Alum. bleeder screw, WIF sensor delete plug, Fumoto oil drain valve, Pacer LED cab lights, GM dually light bar under tailgate, Footwell lights, Cobra 29 WXNWST CB radio, Wilson 2000 CB antenna, Kenwood speakers, GM chrome oval running boards, Bilstein 5100s, Michelin Defender M/S on PY0 wheels, Rubber mud flaps, Curt class IV hitch
HD Dmax Machine is offline
post #53 of 58 (permalink) Old 07-03-2013, 06:41 PM
HDBOWTIE13's Avatar
Great info guys!
SOLD: 06 Silverado 2500HD LBZ LT3 4x4
99 Silverado 1500 classic 4x4 111k
05 AC Firecat F6 Sno Pro
HDBOWTIE13 is offline
post #54 of 58 (permalink) Old 09-24-2013, 07:10 PM
Thank you
wscallen5975 is offline
post #55 of 58 (permalink) Old 02-14-2014, 12:10 PM
BoJangles104's Avatar
Does anyone know if a snap on scanner is able to change the tire pressure sensors? I'm gonna give it a shot this evening
2015 GMC Denali LML
EFI Live Kory Willis Engine and Trans Tunes
5" Flo Pro
S&B intake
Full EGR delete with up pipe
Down pipe
Air dog 4G
Resonator Delete
PCV Reroute
2011 GMC SLT CC LML with many options - Sold
BoJangles104 is offline
post #56 of 58 (permalink) Old 07-22-2014, 03:18 PM
JLiska50's Avatar
Anyone have a recommended tire pressure for 285/55r20 on 20x10's?
2005 GMC Sierra SB Ext Cab LLY
LLY Tapshifter conversion, EFI by Kory, Suncoast GMAX V, 1057, pump rub, FASS Platinum 150, 4" MBRP straight piped, Allseasons EGR delete, PCV Reroute, AFE Mouthpiece, Tie Rods and supports, RBP 95r 20x10's wrapped with Dick Cepek Radial FC-II 33X12.50, Mech boost gauge, Edge CTS
JLiska50 is offline
post #57 of 58 (permalink) Old 08-09-2017, 02:39 AM
Sierraluva's Avatar
Open country AT2's
What tire pressure are you guys running in this size tire? I'm at 65 warmed up and I don't think it's enough. The fronts look low and they are wearing strangely. 305.55.20.
🤘 Kennedy fuel system support hardware, CCM front Diff Drop, some LEDs to make night into day, got some big ol 20's and wide ass tires and a nice display to show me what's up under the hood-
2012GMC2500CCSB
Sierraluva is offline
post #58 of 58 (permalink) Old 08-23-2017, 07:57 AM
modoutlaw's Avatar
Thanks for the info, I have gotten in a pissing match with the dealership the last two times i have been there about front tire wear on the shoulders of the tires. I knew it was too low, I had been airing the front up to 72lbs based on tire temp readings across the front tread, and each time i took it in they kept dropping them back down to 60lbs. I do not tow daily, just on the weekends. I really wonder what their reasoning is for the low front air pressure. Reminds me of what I went through on my 2012 Tacoma. They ended up doing a recall to change the air pressure placard on the door. I'm tempted to put the truck on some scales to really know the wheel weights while the truck is unloaded.
modoutlaw is offline
