Tire time again - 285s for snow and heavy loads - Page 2 - Chevy and GMC Duramax Diesel Forum
post #11 of 18 (permalink) Old 05-15-2015, 07:50 AM Thread Starter
dh dad's Avatar
Originally Posted by dh dad View Post
...my truck camper in the bed and 4 passengers on a certified CAT scale:
Front Axle 4500
Rear Axle 7240
Total 11740
And before any of you decide to start telling me I'm way over my GVWR of a 2500HD save your fingers as I've carried this thing for 8 years without the truck having any issues (additional springs and air bags plus Bilstein shocks have been added in addition to the wheels/tires) and I did my research back on 2006 before I bought the truck:
2007 GMC Sierra 2500HD Classic CC 4x4 Diesel SB
Cepek Hummer H2 17x8.5 wheels rated at 4500 lbs each
Nitto Dura Grappler 285/70r17E tires rated at 3750 each
Supersprings, AirLift air bags
Cognito Leveling kit with Bilstein 5100 shocks
Torklift frame mount tie downs
Titan Class V tow beast
AAM rear axle rated at 10400 lbs
front axle GMC load rating 4800 lbs
Only concern I've ever had are tires and wheels as those are what gets hot especially on a summer trip on the interstate. This rig sits 100% level and does not sway, actually rides like a dream when loaded. Due to the Supersprings it rides like an empty DRW when unloaded
GMC 2007 2500HD Classic CC SB 4x4 Diesel
Cognito Stage 4 Leveling kit(stock keys)
285/75r16 BFG KO2 M/T Sidebiter II Wheels
dh dad is offline
post #12 of 18 (permalink) Old 05-15-2015, 02:46 PM Thread Starter
dh dad's Avatar
OK so on an RV forum someone stated "there is a federal reg limiting 17's and that is why tires are dropping from 37xx and 39xx to 3195lbs"! I thought this sounded ridiculous but in looking at these screenshots from Toyo's website maybe it's true. Notice how every tire size from a 245/75R17E to a 35x12.5E is rated at 3195! Since load rating is a calculation using air volume, heat and tire design this makes no sense. In both 16" and 18" the loads climb as the sizes go up. These are all Toyo Open Country AT2 tires?
Some congressman decided that going forward all 17" wheels will be for 3/4 ton trucks and 1 ton must have 18" wheels and they were too late in the game to make all the tire mfg change there 16" ratings?
dh dad is offline
post #13 of 18 (permalink) Old 05-21-2015, 06:24 AM Thread Starter
dh dad's Avatar
So I've nailed down my tire choice to the Open Country AT2 Extreme 295/75R16E or the BFG KO2 285/75R16E. Both meet my minimum load requirements of 3750, both have 3 ply sidewalls(note that the Toyo OC AT2 is only 2 Ply for 285 and smaller so 285/75R16E is out) and both have good reviews for snow (BFG actually rated for severe snow). I had written the Toyo OC AT2 off until I found out more about the Extreme (XT) versions which are only available in certain sizes. These have deeper tread and better reviews than the non Extreme versions. The Toyo is slightly bigger (33.4" x 11.6") than the KO2 (32.8" x 11.2") and rated higher at 3970. I've fit two different sets of 285s to date, may need to take a close look to see how much room I have to spare for an additional 1/4" front/back and width.
I found two similar angled pics online, which tread design would you choose for snow covered roads (not just wintery conditions but travel before the plows). To me it looks like the BFG side lugs will clean snow better but the center lugs of the Toyo may clear better. May simply come down to fit though, I know the BFG will fit. Both are very affordable at around $200/tire, I may get 5 and rotate all in so to extend my tire replacement duration this time around.
dh dad is offline
post #14 of 18 (permalink) Old 07-14-2015, 11:06 AM
FROGMAN524's Avatar
What did you end up doing?
2020 GMC Denali HD CCSB L5P/10L1000 Allison 4x4
SOLD2016 Sierra 3500HD Denali CCSB SRW
UDP Tunes on V2/SOTF Switch/Danville 63.5 Billet-S480FMW Billet Twins by WCFab(Illusion Blue)/Exergy 100% Injectors/Exergy 12MM CP3/Banks Intercooler/HSP Billet Manifolds/PPE Up Pipes/PPE Oil Pan/PPE Deep Trans Pan/AirDog 165 II-4G/FloPro 5" SS Turbo Back/MBRP 6" SS Tip/CTS2 Insight/EDGE EGT Probe/EDGE 0-100 Boost Sensor/Cognito 4-6/Cognito Front Driveline/Cognito Swaybar/Cognito PISK/PPE Tie Rods/King 2.5 Resis/Air Lift 5000 Ultimate Bags/Air Lift Wireless One Compressor/Wilwood TX6R Brakes Front and Back/LT325/60R20 BFG KO2s/20x9 Method 309s/AMP Steps/Yukon 4.11s/Royalty Core RC1/Retrax Powertrax Pro MX/Titan STAFS 30 Gallon/JL C5s/JL 12TW3-D4/JL VX600/6i/JL XD300/1V2
Mike L Trans (Goerend R/Alto G3s/RatioTek)
SOLD2015.5 GMC Sierra 3500HD Denali CCSB
SOLD2007.5 GMC Sierra 2500HD SLT CCSB SDP Twins/Mike L Trans/ATP Tunes
If wishes were horses, beggars would ride.
FROGMAN524 is offline
post #15 of 18 (permalink) Old 07-14-2015, 11:51 AM Thread Starter
dh dad's Avatar
New M/T wheels and BFG KO2 285/75r16E tires. Snowflake rated and cheap at $200/corner. Tires for larger diameter wheels go up exponentially.
dh dad is offline
post #16 of 18 (permalink) Old 03-09-2016, 07:27 AM
FROGMAN524's Avatar
So how did you like them this winter?
post #17 of 18 (permalink) Old 03-10-2016, 06:48 PM
FROGMAN524's Avatar
Bump
post #18 of 18 (permalink) Old 03-10-2016, 06:54 PM
Milocka's Avatar
I have BFG AT KO2s on my rig. Night and day difference between them and previous Nitto Terra Grapplers. I only had to use 4WD once this winter, and that was after 18"s. The BFGs are super quiet compared to the Nittos. Can't wait to tow the 5th wheel with them.
EFI Live by Idaho Rob, 4" Stainless AFE Mach Force Big Bore DPF Delete, Diamond Eye Downpipe, ISSPRO EV2 Factory Match Pyro & Boost, AMP Research power steps
Leveled with 18" Gear wheels, 285/65/18 BFG All Terrain TA KO2, Pioneer AVH-4100NEX head unit, NOCO Genius Mini2 on-board battery charger
Milocka is offline
