2008 lmm work truck tire size - Chevy and GMC Duramax Diesel Forum
 1Likes
  • 1 Post By Hook'em_Horns!
post #1 of 8 (permalink) Old 07-13-2019, 09:48 AM Thread Starter
My first post, I recently bought a 2008 2500hd work truck. It’s time for tires and I’m wanting to go with a bigger tire than what’s on it now. Currently it has 245/75/r16’s and I am wondering if the rims are wide enough for 265/75/16 or maybe even a 285?
File Type: jpg 9F29558D-29B6-4681-9FA2-FDE9C5D61C9E_1563036424701.jpg (46.6 KB, 44 views)
morkalan2 is offline
post #2 of 8 (permalink) Old 07-13-2019, 09:52 AM
Yes, you may have to turn up the torsion bars if you go with 285's.
mray is offline
post #3 of 8 (permalink) Old 07-14-2019, 06:49 PM Thread Starter
Perfect thankyou, I ordered a set of 285's. Are they gonna be hard to adjust or is that something a tire shop can do when installing tires?
post #4 of 8 (permalink) Old 07-15-2019, 11:24 AM
Maybe, truck has to be jacked up with the tires off the ground to adjust them and then an alignment should be performed which should be done anytime new tires are installed anyways.
mray is offline
post #5 of 8 (permalink) Old 07-15-2019, 02:28 PM
D_R_C's Avatar
If it came with 245's then the rims might not be wide enough which they are probably about 6 1/2" to 7" wide.
285's require at least 7 1/2" minimum width, most tire shops because of DOT guidelines will NOT install tires on a narrower rim than what is required for safety.
265's require a rim at least 7" wide any narrower then you might not be able to get them installed.
You can get on pretty much any of the tire manufactures website to view all specs including required rim widths for every size tire.
285's you'll probably have to crank your torsion bars as mentioned above, I had to crank mine 3 1/4" for clearance, then ended up getting a 4" lift..
Been there dealt with this.
Dan
EFILive TCM Duramax Tuner
DHD PCV Re-Route
AirDog 4G100
D_R_C is online now
post #6 of 8 (permalink) Old 07-28-2019, 02:25 PM Thread Starter
Well finally got my tires installed & went with toyo 265/75/16’s. Rims were surprisingly 8 wide so had no issues with fit. Thankyou for the help.
File Type: jpg 787296DD-27DE-4169-AE44-747D8BC54425_1564349117824.jpg (50.9 KB, 20 views)
post #7 of 8 (permalink) Old 07-28-2019, 02:31 PM
LHN...We ARE the Joneses
Good choice with the 265s...save those front end parts.
MORSNO likes this.
Hook'em_Horns! is online now
post #8 of 8 (permalink) Old 07-28-2019, 06:58 PM
MORSNO's Avatar
So much truth in that! I'm sooo glad I outgrew larger tires and leveling front ends.
2012 GMC Sierra SLT 2500HD Z71
Cooper AT3 LTX's, Reflex Spray-In Bed Liner, Undercover Bed Cover, Undercover Swing Case Tool Boxes, XPel Clear Car Armor Film, UltiMat DashMat, Rear Underseat Storage, Rough Country Stabilizer, F&R Dura Flaps, High/Low/Fog's All On Mod, AMP Research Power Steps, TorkLift Stable Loads, HD Timbren SES
MORSNO is offline
