2019 Denali TPMS Question - Chevy and GMC Duramax Diesel Forum
post #1 of 8 (permalink) Old 08-08-2019, 12:20 PM Thread Starter
Can a dealer lower the tpms settings in the computer so I don't have to have 70psi when not towing? I had a 2015 Silverado LTZ and the dealer was able to lower the setting to 45 or 50 so the tpms light didn't come on. When I asked at delivery of my new truck the dealer said it can no longer be done. I call BS. Anyone know for sure?
TimsGMC is offline
post #2 of 8 (permalink) Old 08-08-2019, 04:21 PM
henry42's Avatar
GM has significantly locked down the dealer's ability to do much of anything these days.
I'm sure that the dealer would have loved to charge you for the time if he could.
“Insanity is doing the same thing over and over again, but expecting different results.” - Albert Einstein
2017 2500HD GMC Denali CCSB
henry42 is offline
post #3 of 8 (permalink) Old 08-11-2019, 06:20 PM Thread Starter
Thanks. Just curious if anyone else has had the dealer kick them to the curb. Or have they been able to do this in your 2017 or newer.
TimsGMC is offline
post #4 of 8 (permalink) Old 08-11-2019, 07:25 PM
long-time-dmax's Avatar
I had read a thread somewhere a while back. Guy had bought a new truck but it was a lower trim model with steel wheels or something like that. The dealer he purchased from was sitting on 4 aluminum wheels/tires they had pulled off another truck they had sold. He worked a deal where they swapped the aluminum wheels and tires onto his truck before delivery but the aluminum wheels were bigger than the wheels that came on his truck. He wanted the dealer to re-calibrate his speedo for the wheel / tire swap. When the dealer asked GM for permission to do so, they were denied. Seems they can't just get into the ECMs anymore like they used to. Apparently GM has to issue some sort of 1-time password or something like that now.
2002 Chevy 2500HD Crew - Original owner - 404,000 miles so far. All stock with the exception of a lift pump and Donaldson filter
long-time-dmax is offline
post #5 of 8 (permalink) Old 08-12-2019, 10:17 AM
pigpen23's Avatar
I had the TPMS lowered no problem on my '18. Cost was maybe 50 bucks if that. Not sure if that changed from '18-'19, but I doubt it. If your dealer says they can't do it, go try different dealers.
Casey
2016 Denali 3500HD - Starting from scratch.
Drop shackles. Tint.
2018 Silverado 2500HD - Sold
2015 Silverado 2500HD - Sold
2012 Silverado 2500HD - Sold
pigpen23 is offline
post #6 of 8 (permalink) Old 08-12-2019, 12:19 PM
The dealer originally told me they couldn’t add high idle on my 2018. But some one had posted the tsb and I printed it out and gave to them. They did have to call GM but they did it.
MIkey52 is offline
post #7 of 8 (permalink) Old 08-12-2019, 06:24 PM
denarli6.6's Avatar
It all depends on the dealer, but they have the ability to lower it. My local dealership questioned my reasoning for doing it and said they would do it for $150 when I told them it will not be used for towing, but street/ performance applications.
2016 LML Denali 2500
Reverse level with Mcgaughy's 2" drop shackle
Bilstein 5100 all-around
22x10 American Force Flux black w machined
Wehrli S300 kit w/ 66mm SXE
Profab Manifold & Up-pipes
Stock Trans For Now
Stock Sticks For Now
Air Dog 165 4G
Off-road Only
denarli6.6 is offline
post #8 of 8 (permalink) Old 09-12-2019, 07:21 AM
powerhaulic's Avatar
Many dealers will not do it.
Some will, It is a change in the BCM that can be done if the tech is willing.
I had my '18 done, and now my 2020 is also lowered.
I run 48-50psi rear when not loaded and 65 front.
They are instructed to not do it so as to protect themselves for liability reasons, because we are not smart enough to inflate tires when running heavy loads.
2020 Sierra AT4 3500 Duramax
2018 Denali 2500HD L5P Derringer equipped
2018 Montana 3811MS Legacy 16400#2900pin
powerhaulic is offline
