19.5 conversion 2006 gmc 3/4 - Chevy and GMC Duramax Diesel Forum
post #1 of 8 (permalink) Old 08-20-2019, 09:08 AM Thread Starter
cbigdaddyr@aol.com's Avatar
Is it worth the cost
post #2 of 8 (permalink) Old 08-20-2019, 01:37 PM
Do a search n here, some has done it and itís very expensive. The ride is worse, but the mileage on tires go up.
MIkey52 is offline
post #3 of 8 (permalink) Old 08-20-2019, 02:23 PM
05 3500 2wd's Avatar
Big expense, rougher ride, more stable with heavy loads, longer tire life and look great. I got 65,000 out of my set of Goodyears with 50% of that loaded Heavy and towing. The tire can get old before the tread wears out depending on climate, storage, weight on them, and tire type. The Goodyears have a UV guard in them to help the breakdown.
Clifford is a 2005 GMC Loaded SLT 2wd with; true cold air intake mods, ported LBZ turbo inlet mouthpiece, AFE Inter cooler pipe, Diamond Eye down pipe, BD drivers side manifold, V2 radiator, thermostst controlled oil cooler, Edge CTS2, 19.5" aluminum wheels with factory lug covers, Goodyear G647RSS 225/70/19.5, BF Xenon 6000k Headlights Low & Hi, Air lift Remote control 5000# air bag system, Tork Lift Stable Loads, EZ down Tailgate assist, Put co S/S mud flaps, compete interior wood dash kit, Dual Liner 3 piece bed liner with rubber floor mat, Roll-N-Lock tonne cover with tail gate lock, and AVS in channel vent visors.
GM DRW club member #5
05 3500 2wd is offline
post #4 of 8 (permalink) Old 08-20-2019, 05:29 PM
JimmyD's Avatar
^^This^^
09 GMC SLT Dually
Steel Gray Metallic
All options except sunroof
Mods so far:
DF DRW Club Member #161
JimmyD is offline
post #5 of 8 (permalink) Old 08-20-2019, 10:29 PM
D_R_C's Avatar
Why donít you just go with 20ís probably less hassle and easily available.
Dan
EFILive TCM Duramax Tuner
D_R_C is online now
post #6 of 8 (permalink) Old 08-21-2019, 10:04 AM Thread Starter
Looking for load capacity. Haven't found any 20's with a G rating
post #7 of 8 (permalink) Old 08-21-2019, 10:32 AM
D_R_C's Avatar
That might be hard to find except for RV and trailer tires, just curious why do you feel the need for G rated on your truck.
If this is for your truck there's several 20's available that have a load rating close to what a F would be' and even G's.
If you have the $$$ to spend, I guess, you must want the look of the wheels that usually go with 19.5's.
I'd be concerned going with the conversion hauling weight, if your truck was built this way it'd be safe, conversion
The general rule if you are able to get higher mileage out of tires which usually has harder rubber which = not so great traction on wet roads or off road.
Good Luck
Dan
D_R_C is online now
post #8 of 8 (permalink) Old 08-21-2019, 11:43 AM
jdwarren's Avatar
And I doubt you will, 18" and 20" are considered light duty, and 19.5" are considered medium duty. If you need G or H load ranges you'll have to go to 19.5, most likely.
That said, there are load range E tires that fit 20" wheels that have load capacities of over 4k lbs. Example: https://www.tirerack.com/tires/tires...DLTX&tab=Sizes
2017 Silverado 3500 LTZ (Summit White) | CC SB SRW | Z71 | Duramax L5P | Undercover Ultra Flex bed cover | Draw-Tite front receiver | AIMS 3kw inverter-charger | Titan Travel Trekker 50-gallon auxiliary fuel tank
jdwarren is offline
