NEW! XDP X-TRA Cool Direct-Fit Transmission Oil Cooler XD310 - LBZ/LMM - Chevy and GMC Duramax Diesel Forum
Xtreme Diesel Performance
 1Likes
  • 1 Post By SilverGorillaLML
post #1 of 7 (permalink) Old 01-08-2019, 10:11 AM Thread Starter
XtremeDiesel's Avatar
XDP X-TRA Cool Products has expanded into Transmission Coolers! The XD310 is a new replacement cooler for the 2006-2010 GM 6.6L Duramax trucks and features a high-efficiency core. Like our X-TRA Cool Radiators, this Trans Cooler is built using construction techniques borrowed from the HD and Semi-Truck Industry. Each cooler comes ready for installation with necessary brackets and hardware.
Find out more here:
https://www.xtremediesel.com/xdp-x-t...l-cooler-xd310
Duramax Forum Members Save 10%!
Like us on Facebook for News, Contests & Giveaways!
Call Us @ 1-888-DIESEL4
XtremeDiesel is offline
post #2 of 7 (permalink) Old 01-14-2019, 11:13 PM
Any reviews on this?
2008 Chevrolet CCSB Duramax - dpf delete, egr delete, pcv reroute, hsp cold air, hsp billet thermostat housing, hsp y-bridge cold side combo, banks ic pipe, efi tuned by ppei, FASS lift pump, dmax store downpipe, 5" mbrp exhaust, trans go jr, htt Promax 64, ppe shim kit, ppe ported rail fitting, bd drivers manifold, arp head studs, limitless diy kit built by me, limitless 1078 converter
20dmax08 is offline
post #3 of 7 (permalink) Old 01-22-2019, 02:24 PM Thread Starter
PM on the way.
post #4 of 7 (permalink) Old 06-02-2019, 12:24 PM
lockcop's Avatar
I'm also interested in this trans cooler. The PPE is $100 more and am wondering if the old adage - you get what you pay for - is applicable here. I tow a 5th wheel in AZ during the summer - mucho heat, and am pondering upgrading the cooler. Why should I buy the XDP cooler? I've already upgraded the lines.
Kenneth a.k.a. lockcop 2007.5 LMM 2500HD ECSB 4 Wheel Drive
EFI AutoCal by Idaho Rob; DSP5 Switch In Power Port; Edge CTS2 with Pyro; Deviant Trans Lines from Alligator Performance; PPE Deep Trans + Oil Pan (TRANSYND), AFE Differential Cover + Trans Cooler from XDP; FASS T95 Lift Pump from Synthetic Motorsports; XD Tie Rods + Fumoto Valve from the DMAX STORE; ; POWERSTOP Z36 Drilled + Slotted;TIMBREN Suspension Enhancement System; Quad LED Fog Lights; OWENS diamond plate running boards; AERO 52 GAL Tank; Turbo Brake w/switch and light; Amsoil 20-50 Dominator Oil; Schaeffer Moly Grease, + Gear Lube; Temp Sensors In Oil Pan + Rear Diff; Dorman PS Cooler; Flowtie Emblem, Hillsboro 3500 Aluminum flatbed
Arizona Diesel Club #11
lockcop is offline
post #5 of 7 (permalink) Old 06-02-2019, 07:46 PM
SilverGorillaLML's Avatar
Mike L cooler. Call Inglewood transmissions
AlisoBob likes this.
"Flat Back Gorilla" Daily/Tow rig- 04 GMC Sierra LB7 CC Flatbed/Tune/Exhaust
"Empty Pockets" Race/Pulling truck- 2012 CCSB Cummins/Built Engine/
Full Billet 48RE Swap controlled by PCS2000/
B&M Ratchet shifter/Big fuel/Big air/Lowered
SilverGorillaLML is offline
post #6 of 7 (permalink) Old 09-21-2019, 09:28 PM
lockcop's Avatar
Threads for both fittings were not correct. Had to use oil and a lot of back and forth to get my lines to thread into your new cooler.
lockcop is offline
post #7 of 7 (permalink) Old 09-23-2019, 11:17 AM Thread Starter
PM on the way.
