1 - 7 of 7 Posts
Hey all.A friend of mine just bought a 2001 GMC 2500 with LB7.The check engine light was on so I used my Autocal to pull the following codes:
SRS U1041
PCM P0380
PCM U1000
PCM U1041
The previous owner had pUlled the ABS fuse because he claimed not to lIke ABS.The codes still come up with the fuse put back in.
The P0380 code seems glow plug or glow plug relay related.If one GP is bad will it throw this generic code rather than pinpoint which glow plug is defective?
Thanks for any help.-Poo.
Could be a plug but more likely another issue as well is the controller. You can test the plugs though, and they aren’t expensive.
Abs is more than likely one of the two front wheel bearings or sensors. I recommend replacing both hubs as they go out and can cause other issues. New hubs have the sensors in them so there is that. Could be the controller but hubs are more likely.
2004 Silverado Cali lb7, Airdog ll 165, fresh sticks at 325k, Rick Fletes Dsp 5 on v2, 33x12.5 nitto at on 20 inch American Racing 20x10 wheels, Stage 5 Built Transmission by Mike Cole with triple disc billet low stall converter, 4 inch Injen cold air intake, Profab Intake Horn, Batmo Wheel, PPE Race Valve, Full EGR Removed w/ fed belt, 3.5 inch MBRP Downpipe, Full five inch MBRP Exhaust axle dump, lbz cp3 pump, Dual Platinum AGM Duralast, High Output Alternator, Cognito Pittman and idler w/ support kit, Cognito Upper Contol arms, Drilled and Slotted Rotors on all four Corners, FED Y Bridge, Shantz Custom Fab Traction Bars.
Thanks t.ashton for the reply.
Your sig says "fresh sticks at 325k" .Did you go that long on the original injectors?
No, that’s my third set
Discussion Starter #6
Averages out to less than 110k per set,yikes.
No sir, first set made to 205k, second set to 325k, on my third currently. I didn’t do all the mods to really help my longevity until I started having issues with my second set.
1 - 7 of 7 Posts
