Does it show any codes, sorta sounds like maybe the Fuel Injection Control Module.
only code that shows up is related to shorted glow plug! my injectors balance are all 0! when I unplug the ficm harness, it throws a code! not sure how to test ficm!Does it show any codes, sorta sounds like maybe the Fuel Injection Control Module.
sounds normal while cranking! Im guessing ecm or ficm! not sure how to test themIf won't fire on starting fluid I would be checking compression..
Make sure it's not something mechanical..
You stated it does nothing with starting fluid.. Is this correct?sounds normal while cranking! Im guessing ecm or ficm! not sure how to test them
Doesn't this indicate that the injectors are doing nothing?? they aren't firing??my injectors balance are all 0!
You have fuel and fuel pressure just find. Now I wonder if the injectors are being activated. Leaning towards FICM problem along with MRAY
thats correct! doesnt do anything!You stated it does nothing with starting fluid.. Is this correct?
yes! it does show rpm! previous owner replaced the engine, it was running for 1 month! parked then never started again!I’m with @Ottowood on this- if it’s not doing anything with starting fluid or similar, you need to check compression.
Do you have a signal from the crank sensor telling the scanner rpm?
did you get any codes when your ficm went out?When the FICM went out on the 01 for some reason it wouldn’t fire on starting fluid.
not too sure! yesterday I hooked up the same scanner on a 6.6 duramax newer truck that runs, the balance rate was all different! every single injectors had different numbers! with the key on and engine not running! but the lb7 that Im working on and doesnt start shows all 0!Doesn't this indicate that the injectors are doing nothing?? they aren't firing??
Very well could be….Doesn't this indicate that the injectors are doing nothing?? they aren't firing??
It does show rpm so that’s good. I’m questioning a bad ficm as well at this pointyes! it does show rpm! previous owner replaced the engine, it was running for 1 month! parked then never started again!
I’ve seen several ficms go bad with no codes show. Best way is to get one from an operational truck and plug it in to see if it will start. If it does, then that means the ficm is baddid you get any codes when your ficm went out?
I did get a code for lost comm. with FICM. Not trying to steer you in the wrong direction but also know of the FICM going out with no codes. Sometimes there’s no rhyme or reason for them going bad. I agree with DMaxFF if you have access to another one I would try it. They are plug and play on the LB7.did you get any codes when your ficm went out?
