Have a 2002 Silverado 2500 HD with the Duramax. The truck wouldn't start one day, had no power at all. Batteries are under 2 years old. I noticed some corrosion on the at the terminal end of the battery cables so I cleaned them up. Still no power at all. So I went home to get my meter and came back. I disconnected the batteries from the cables and tested with the meeter - both are good, around 12 volts. I re-connected and found that I have power. Tried to start and the starter just clicks. Looking at the forum, I have several things to check out.
However, I have one question concerning power from the batteries. My dad thinks that only one battery would be live all the time and the second one would be engaged when trying to start. Is this true?
The reason I ask is, when I had the batteries disconnected to test them, the drivers side battery sparked when I was connecting the negative cable (did positive first). When connecting the passenger's side battery, I connected the positive, then kept hitting the terminal with the negative and couldn't get it to spark at all. I figured it should if there is a circuit.
thanks in advance for any responses,
-Darell
-Darell
