my 02 lb7 started smoking heavy white smoke at idle and under acceleration ,i pulled each glowplug and #8 was soaking wet in fuel pretty sure injector 8 is stuck open. i ordered an injector block off tool, gonna see if blocking off that injector will get rid of the smoke... my plan is to replace all 4 injectors on driver side, anything else i should look into before replacing injectors?
Discussion Starter · #2 ·
block off tool arrived ... blocked suspect injector and white smoke is gone exhaust does not smell like pure fuel anymore
Plans?
Thanks for following up and welcome!
I wonder how well an LB7 runs on 7 cylinders?
Knowing what a pia R&R of all injectors can be, I wonder if I would be in a rush to go all in.
Signature line, please.
