1 - 7 of 7 Posts
The truck recently started knocking when you would start it then would go away. Now it knocks loud when its idling but goes away when you give it some throttle. There is no codes or check engine light. I am not with the truck now but will be tonight if y'all can help me out i would appreciate it.:help
It could be injectors... Can u check balance rates... How many miles on them?
Sent from my Autoguide iPhone app...
I can check the balance rate with my v2 i believe. But it is a loud knock. The injectors have about 15000 to 20000 on them
Check the oil for metal.
Discussion Starter #6
There was very little metal in the oil no diesel in the oil either. It sounds more like the torque converter or flywheel. When you put it in drive the noise goes away.
Discussion Starter #7
Bump
1 - 7 of 7 Posts
