1 - 8 of 8 Posts
so after getting my truck back from new head gaskets and studs with egr block off plate with pvr lines cut i have found coolant running down between oil pan and trans. after looking around found coolant in the valley below turbo. what is wrong and how hard is it to take turbo off? please help
Discussion Starter #2
help me someone please
Make sure all coolant lines got put back on and not cut.
how hard is it to get the turbo off? or can i get around with out doing that
It is not that bad of a job. Have you traced it to where the leak is I would start the truck get your flash light and find the leak.
Discussion Starter #6
its coming off the turbo coolant line under turbo i think. i can see coolant under my turbo in my valley. after turbo cools down when it is parked running for 10 to 15mins i can see it run down around my motor. should i take my turbo off or egr cooler
Discussion Starter #8
yeah but i hear theres a seal that maybe the reason
1 - 8 of 8 Posts
