Hi all, New to the forum, looks like a wealth of information here, perhaps you can be of some assistance to me.
A few weeks ago I was driving home from a class I'm in, and my truck just died. 2004.5, LLY CCLB 4x4 6.6 vin 2 . It was as if I shut the key off, but nothing else died. Just a light sputter and died. As I coasted to a stop I popped into neutral and tried to crank, but no start. No previous cel problems, had filled up with fuel the night before (had about 1/4 tank fuel). Checked around a bit before having it towed home. At home, I had fuel at the bleeder, and solid fuel while priming. Had serviced the truck right before new years, so the fuel filter is pretty fresh. Cranks, but won't start. Scanned ecm, no current codes. Had 2 history codes, one being lost comm with FICM, the other a FPR ckt malf, but not current. I cleared codes, cranked several times, nothing reappears, and no pending codes either. no fail since clear either. I also tried to look over every inch of harness on the engine, and don't see any rub through or short isues. I have a buddy with identical truck so we swapped FICM just to be sure, his truck runs with my FICM, so no prob. there. I've replaced the fuel filter during my testing, solid fuel out to the bleeder, and removed vaccuum ck port fitting and have solid fuel out to there. Placed a vaccuum gauge in line at ck port, have no draw while cranking. I do have voltage out to fuel regulator solenoid , and can hear it whine from the current flow. My residual line pressure showed at about 150psi, requested is about 5500, pressure while cranking got max of 250-350. Again, no draw at ck port though. It appears to me that my fuel pump has taken a dump on me. I removed the Fuel regulator solenoid and supplied it with 12v, and the plunger moves no problem. The only issue I am having is that I don't see anywhere where anyone seems to be having problems with these pumps. Has anyone else had any issues with their pumps failing on an LLY? I see lots of fuel regulator solenoid issues, but not the actual pump. Anyone have any thoughts on this? I believe I've covered my bases pretty well....all signs point to a pump failure. The other thing I did notice is very small aluminum particulate on the top of my fuel filter when I removed it. I don't know if some of that particulate may have passed into my pump, and if so I could see that causing a failure, but it sure seems that it would have been caught by the filter prior to entering the injection pump as that is pretty much the last thing in the way on the inlet side. Thoughts? Experiences?
Your information is certainly appreciated, It looks like I'm looking at about $700 or so for a reman pump, so not the end of the world. I would just feel better about it if I could find a few other people that have actually had this problem.
THanks again, :help
Jon
THanks again, :help
Jon
