I know this subject has been beaten to death for the last 15+ years but I am posting this just in case someone has figured out the ACTUAL reason why these engines do this. I've replaced several starters, 2 ring gears and employed ALL of the tricks and tips I've found on various forums over the years. I've checked/replaced both batteries, checked and remade wire connections, all to no avail. I'm at my wits end here and just want to get rid of this truck, but not until I can feel assured that it will start when I trade it in for a Dodge, or a Ford, or a Nissan, or.....
I think if you search for posts about this you will find some answers. I believe there are some spacers that fix the alignment. Not having an LLY, nor any starter problems, I didn't pay great attention to the detail.
I put a new flywheel and starter in mine. Made sure the alignment was good and that was it. That was years ago and countless starts and cold starts since.
My 2005 LLY did the starter grind about 90 percent of the time.
I now turn on the ignition and wait until the computer has done its thing. I wait for the heater/ac fans to come on and stabilize. Then I start the engine. It has not done the grinding since. I have not replaced the starter or any other starter related items. While I am waiting for the computer (less than one minute) I put on the seat belt and check my mirrors for any adjustment that may be needed.
This.
The two times mine has done this (within 2 weeks), I had jumped in and tried to start it while the glow plug light was still on.
I feel if you don't wait, there is not enough juice to force the starter plunger deep enough (giggity) to catch the flywheel.
I've made sure to wait the extra 3 secs before turning the key, and it hasn't happened in 2 years.
Sent from my google machine
Reactions: BlownL36
