when you pop the hood you'll see the alterinator and almost directly below the and to the left of the alternator you'll see a pully tightner release the tightner and the belt should come off quite easily.you can try this before you take the shroud off,but with the shroud off you 'll have more room to work.if this makes any sense.hope it helps
