Towing boat home from lake last night and felt like the tranny came out of gear and then the Service 4wd came on across info panel. Checked to see if truck was in 4wd and was not. Continued to the house 50 min later Service 4wd light went off and the Security light came on. Could not get the Security light to go off, also killed power to the steering wheel and the power rear crew cab windows and door locks. Turned truck off and let it sit for 15 min and cranked it back up with no service lights on. Towed 40 miles to work with no problem. Drove to metal shop 2 miles down road. Tried to crank truck up and it does but will shut off after 1.5 to 2 seconds. No check engine light on. It has been 4200 miles since last fuel filter change and get all my fuel from same station ( 271,000 miles worth of diesel ). Have had no trouble out of truck to date. I got truck with 110 miles on it. PPE tow tune, 4" turbo back by by kitty, air intake mod.
Sorry for the story but thought that everything that has happened in the last 24 hr might be pertinant. Thanks for the help in advance!!
