1 - 2 of 2 Posts
Just bought 07.5 lmm Duramax and I believe it has Allison 1000 in it. Can some one tell me part number of screw on allison filter. Also tell me how much fluid i will need if i drain tranny from plug and put in new filter.
Welcome! Yes you do have the 6 speed allison tranny. If your not low on fluid from the start. Then I believe it should be right around 7 quarts. The allison filter number is AT29539579 ,but you can run others like a Donaldson as well. When you change it make sure you remember to keep the magnet of the old filter. New ones will not come with a magnet. Also do yourself and your tranny a favor and use Transyd fluid in it. Its the best.
http://www.duramaxforum.com/forum/dmaxstore/18792-transynd-allison-service-package-fluid-filter.html
1 - 2 of 2 Posts
