07 c5500, p0658 code
1 reading
770 views 4 replies 3 participants last post by  C550007
Hi, 07 c5500. Truck limp mode, changed solenoids, internal harness, code still there. Cleaned battery terminals, check grounds, disconnect alt, still there. Loosing hair
If anyone has had this issue please let me know
Thanks
For the P0658 code on your 2007 C5500, check the wiring and connectors to the transmission control module (TCM), as damage or corrosion could cause the issue. If the wiring is fine, consider testing or replacing the TCM itself. Also, verify voltage and resistance in the actuator wiring (shift solenoids) and consider checking or reprogramming the ECM/PCM if the problem persists.
