Whats happening everyone? I have a 07 LMM with about 98K on it. It is a stock truck with only an aftermarket brake controller on it. Friday as I was leaving work, I noticed that the volt gauge was reading greater than 14V and stayed there for the entire trip home ( approximately 10 mins). I drove the truck all weekend with no issues. I pulled my camper from it's winter spot to my house to get ready to take up to the camp ground. Parked it for the night.
When I got up this am to go to work. I jump in and I get a single click. The lights on the dash light up and then dim out except 2 yellow lights. One that looks like a transmission type light and beside it a spiral squighly light (LMAO. I dont know how else to describe it) and my cd player kept making a clicking noise like it was trying to change disc.
The interior lights light up when I open the door and my keyless entry works still with no problems. Any thoughts? At first I was thinking that I'd charge the battery and/or get a new battery however I was talking to someone from work and I told them about the greater than 14V reading on friday on the way home and they suggested that my alternator could be going bad. Any thoughts?
This is my first diesel so I'm pretty unfamiliar with it. Any help would be greatly appreciated.
Thanks
Josh
Most likely you have bad batteries--over charging from the alternator suggests that a battery is shorted internally and the alternator is trying to bring the voltage up.
The Duramax has two batteries, and they are connected together to make one BIG battery. It takes a lot of amps to turn the the high compression engine over and build sufficent rail pressure. Be sure to replace them in like pair, if they show bad after testing. Be sure they isolate the one being tested or the test will be invalid.
Moved to LMM-- no further response from OP
The "spiral squighly light" is your Wait to Start light.
Lmfao. Thanks bud. I wasn't sure what that was.
So I jumped the truck and took it into the battery shop. They checked my alternator. Checked out ok. Both batteries seemed checked out ok also. 800CCA each.
I put the batteries on a charger. I guess will see what happens. Seems to be running ok for now.
