Ok so i removed the blower motor and hooked to a battery to find out it still works. The wiring is fine and i know its not the resistor because it works on high. There is power to the motor at all times and is controlled by the ground i can make the motor run in the truck by jumping a ground wire to the plug in. So is the hvac switch bad?
Most likely it is your resistor. When on high, there is a relay that bypasses the resistors and sends battery voltage to the motor. The lower speed settings run through a series of resistors to limit current and slow the motor.
Every blower I have had that worked on high and not lower speeds. the issue has always been with the resistor.
I ment to say it doesn't work on high sorry.
Most common problem is the resistor. Be sure to replace the wire connector at the same time as the resistor.
I'm pretty sure that the high speed relay is in one unit with the resistor board. Unless that changed with the NBS, someone correct me if I'm wrong. It was only a $20 part on my 02 but yours it a bit more costly.
