1 - 12 of 12 Posts
Discussion Starter · #2 ·
I figured I'd throw this out there, but after looking at this kit I'm questioning a few things. My understanding thru research and talking with others in the diesel industry is that the 369 SXE with the 73mm turbine is a lot more restrictive than the VGT chargers with the vanes open. Due to this wouldn't the drive pressures be thru the roof at higher power levels or will that all be controlled thru the tuning making sure the vanes in the VGT don't outflow what the S369 turbine can handle?
I seen that a little while ago too. They say up to 650 rwhp.
But would the drive pressure be any greater running this compound setup vs running this 369 as a single?
Sent from my SM-G977U using Tapatalk
what kind of power are you making w/ your set up?looks interesting.I like this truck,but its a slug compared to my 02.need to get some of the fun into this truck.
what kind of tunes did you get w/ your ez lynk ?
I should be around the 600 hp or possibly a little over, not sure exactly. All I know is it's more than the stock transmission wants to take a regular basis so I've been trying to take it easy lol.
I see over 60 lbs of boost under full throttle on my biggest tune so it definitely rips pretty good.
And I just have the normal tune that Kory offers for my setup, position 1 is just a lot less fuel than position 5.
nice
I bet your easily 625-650 on the big tune.
Now that you say that i'm guessing it would be close if not the same as to running it as a single since its the low pressure turbo in this specific set up that would be the choking point.
Has anybody actually ran this compound setup?
2015 GMC Denali 2500HD
How do you like the S475 over stock turbo for towing? Do you have manifolds and up-pipes as well? I tow very heavy constantly and having a 10MM CP3 on stock turbo makes for a smoke show sometimes. I need more air to clean it up a bit, just curious if that’s the route worth going or doing something like a stealth 64. Because I tow so heavy frequently I want to keep the factory exhaust brake and prefer a drop in turbo or a compound set up.
I would log your truck and send it to your tuner. The 10mm pump on stock injectors shouldn’t be making it a smoke show.
I should of specified, it’s a smoke show in tunes 4-5. Granted I don’t tow in those tunes I tow in tune 2 but it will throw puffs if it’s climbing up a grade or if it downshifts from 6th to 4th.
1 - 12 of 12 Posts
