Hello,
Im new to the forum, hope someone can help me out.
Doug rear pads and rotors on my 2016 2500hd lml. I can tell the rear wheels had never been pulled off for any sort of reason on this truck prior to my buying. Everything was quite corroded and rusted. Ended up gettin the wheel of with some persuasion as well as caliper and caliper bracket. The part giving me an issue is the rotor and the stupid shoes on the inside of it for the Ebrake. I backed off the tensioner screw. Pounded on it for quite some time, and well as screwing bolts Into the two holes on the face of the rotor. I have had no luck getting this thing off. The shoes are loose I can tell and the rotor does wiggle and pull away from the hub. But I can feel a springy tension on it when I pull it away. Not sure if anyone else has had problems with their 2016 but if anyone has any advice or tips anything would be greatly appreciated.
Thank you,
Ethan
Thank you,
Ethan
