1 - 11 of 11 Posts
CHECK US OUT HERE FOR GREAT PRICES 1999 - 2002 Chevy Silverado 3500 Power Heated Towing Mirror Pair
FREE SHIPPING IN THE LOWER 48 STATES!!!!
UPGRADE!!!
Bolt-on and plug-in NO modification necessary for trucks with power or power heated mirrors.
Heavy Duty style mirrors that fit 1999-02* Silverado, Sierra ,Suburban, Tahoe, Yukon and Yukon XL. These mirrors have the rugged and cool dual arm angular look. The dual arms manually extend out 4 inches to help keep an eye on your trailer. They also feature a split view. A nice big 8x7 flat mirror on top lets you see just about everything. To cover the blind spots the lower mirror is a 3X7 wide angle.
Mirror features & specifications:
Comes as a Pair
Correct large washer nuts included. (Originals can be used if desired)
Power main mirror
Plugs in to your existing harness
Heated (works with your rear window defrost just like the original)
Manually telescoping mirrors
Manually adjusted lower convex mirrors
Makes a great upgrade to any GM truck that will be towing trailers
If your truck had the signal light in the mirror and/or the puddle light these mirrors will still mount and plug in as original but do not support these options.
The telescoping body of these mirrors are similar to the towing mirrors found on 2007-08 new body style trucks. The base and electrical plugs for these mirrors will match your 1999-02 model.
These mirrors are manually telescoping with electric movement on the main mirror glass. They are also heated.
1 Year Warranty
This item is backed by a 1 Year Manufacturers Warranty. In the event this item should fail during intended use, we will replace the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty.
I'm That Guy...
Looks like a good deal, I'll need to pick a set up in a moth or two.
Are these back in stock yet ?
Have an 02 Chevy power and heated and also what mirror has a light on the out side for these trucks ?
Thanks
Discussion Starter #10
Thanks
Those particular mirrors do not have the exterior turn signals, this set does though. If you do not want the chrome mirrors, reply back with the series of your truck and I'll see if we have a black set for you with those options.
2002 Chevy Silverado 3500 Power Mirror Heated Towing Telescoping Smoked Style Signal Chrome Cap Upgrade Pair at 1AAuto.com
Thanks,
Tony
1 - 11 of 11 Posts
