I got a 01 duramax that's leaking tranny fluid and can't find the leak the truck has 314,000 on it and jut started today and wouldn't move till we put tranny fluid in it
me too. thought it was converter seal but it did not fix it. i have 304k miles. seems to be coming out inside front bell housing by filter
check pto gaskets, pan, dip stick tube, seals, and so on. if you cant pin point it. clean it off and run it to see if you can find it form.
AKA treyfox11
Did you check the bolts inside the bell housing that have rubber washers ?
