I posted once about this and havent gotten any response. hoping i could explain a little better this time to see if anyone could point me in the right direction. I recently replaced my cp3, ive had several fuel issues, some as simple as the fuel filter, ive had several leaks, the biggest one being the cp3, anyway. this time ive tried every thing i know to when narrowing it down but ive had no luck. the issue i have now has me lost. im currently going to a tech college for diesel, ive done a set of injectors on an lb7 before just not on mine. the symptoms its having is very similar to the lly injector pig tail problem but its only showed a code once an it was p0203 if i remember right which would be cylinder #3 injector fault of some sort. ive researched all over trying to narrow it down with out taking anything apart, i had been running it with only one battery so im wondering if it could be the ficm rather than injectors, because i know if you dont have enough voltage it can mess with the ficm. however i know its getting close to needing injectors any way it has a slight has at idle but not while driving. ive got nearly 160 thousand on it so its getting about the time for injectors. the injector rates were all with in the range of -4 and +4 all of them being -4 except cylinder #s 1 3 and 7 which were + 1 or 2. the problems were instant rather than over time, there no blow by at all so i dont think it dropped an injector tip. if anyone could give me some advise thatd be wonderful thanks
