I ordered an AC/Delco MAP sensor from Rock Auto (part # 213796) and installed it on the passenger side intake manifold. Once I hooked it all up, I now keep getting a P0238 code. After doing some research, it seems I may have a Turbo boost sensor and a MAP sensor. Does this sound accurate? I can't seem to get a 100% certain conclusion.
Are the two sensors different part numbers? Did I put a MAP sensor in the Turbo Boost Sensor location?
I found an exact looking sensor on the driver side, underneath the two large wiring harnesses. Is that the MAP sensor?
See photos...
See photos...
