2002 lb7 duramax wont run
I have a 2002 duramax lb7. This truck is completely stock other than a straight pipe as far as i know. I bought this truck not running and burnt on the inside. We got it home, primed the fuel and it finally fired off. I drove it in our building and it has been sitting for around two years now. We replaced everything on the inside: steering column, seats, dash, carpet, everything. Now this truck will not start to save its life. I have primed up the fuel and it stays prime for days. I checked all the fuses and they are all good. We have a cheap autozone scanner and it only has two codes; P0380(Glow plug heater CKT A malfunction) and P0700(trans control Sys malfunction). I can clear them and the glow plug comes right back but it takes the trans one a while to come back. Is there anything else i can do to try to get this to fire off? It has dead batteries but i have two optimas hooked up with jumper cables to it and it turns over fine. I dont want to buy batteries and this thing still not run and they go dead. Any advice would be greaty appreciated. Thanks
